Permanent audio mute icon
A_3_Headed_MonkeyA_3_Headed_Monkey Posts: 13Members, Plex Pass Plex Pass
Hi Guys,
My Rasplex has permanently on screen an 'audio muted' icon. It doesn't seem to affect the audio (ie. audio works fine over HDMI), and I've looked through every setting to see if there some audio mute setting somewhere activated. If I muted and unmute via the playback controls, the icon still remains at the top of the screen. It is not the TV mute. I have changed the skin and it still appears. It is always on screen through all menus and video playback. It does not appear on my other plex clients - only the Rasplex. Running current firmware.
It's not a major issue, as everything still seems to work fine - however if I could get rid of it it would be even better.
Any ideas?
  • simtrasimtra Posts: 30Members ✭✭
    I don't know if you had a keyboard hooked up to your Pi, but have you tried pressing "F8"  That is the key used in XBMC to mute the system and it shows that icon on the screen.
  • LongChairLongChair Plex Dev Team Posts: 671Members, Plex Pass, Plex Ninja Plex Ninja
    can anyone reproduce this one ?
    Plex Dev Team
  • A_3_Headed_MonkeyA_3_Headed_Monkey Posts: 13Members, Plex Pass Plex Pass
    Thanks Simtra - I thought about that after I posted. And then tried to find a keyboard in the house. I found one wireless keyboard with no receiver, one receiver with no keyboard (different to the other one), A PS-2 Keyboard which I tried with a USB adapter but no luck..... just wasn't meant to be.....
    I'll 'borrow' a keyboard from work today and try it - I suspect you may be right.....
  • elwood65elwood65 Posts: 1Validating, Plex Pass Plex Pass
    f8 worked
    from memory, connecting a keyboard worked... thanks
