Batch Script to remove all index.php/ from forum linked posts/topics
sa2000sa2000 Posts: 30,440Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
Would it be possible to run a batch job to edit all links within posts for forum topics / posts to remove the /index.php
eg
replace link to
https://forums.plex.tv/topic/164829-this-server-cannot-reach-the-internet-please-verify-connectivity-and-try-again/
with
in post that has the link
Help given free on forums.            Fee-Based Personal Support & Help.
_______________________________________________________________________________________
Plex Support Information              Troubleshooting               FAQs
Plex Media Server:   Reporting Issues        Plex Web App: Debug Log    Plex Apps: Support pages and Logs    Logs: All Logs
Please do not send logs by Private Message unless specifically requested to
Best Answer
Answers
  • OttoKernerOttoKerner Posts: 28,460Members, Plex Pass, Plex Ninja Plex Ninja
    I've asked about this. A solution is in the works.
    Search/replace in the database would invalidate all links cached by search engines. So I think the eventual solution will look a bit different.
    Got help? Help others too - by reporting back with your results!
    Have you checked the Documentation before posting a question in the forums?
    Use the SEARCH function before starting a new thread!
    No PMs unless requested, please! Do not use 'verbose' logging
  • war59312war59312 Posts: 52Members, Plex Pass Plex Pass
    Rewriite should be easy enough. Simple enough to "drop" the index.php.
    God Bless U.S.A - Congrats Ladies. :) Champs of the world!! :D
  • sa2000sa2000 Posts: 30,440Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    Appears to be not just removing index.php
    Where there is a link to a specific post then the post number is now a comment number but url syntax is completely different
    See issue highlighted here which needs to be incorporated in any re-write that will be done
    https://forums.plex.tv/discussion/173012/query-string-from-old-links-causes-404s#latest
