Not Connected....Unauthorized....etc
marsengillmarsengill Posts: 2Members ✭✭
I have Plex Media Server running at home. My 2 son's iPad Minis had the Plex app and played fine. I upgraded and now it just won't show any media. Not connected or Unauthorized are the messages I keep receiving. What is going on? Can you please help? Thanks!
Best Answer
Answers
  • marsengillmarsengill Posts: 2Members ✭✭
    Thank you VERY much. I will try this tonight when I get home.
  • topmarktopmark Posts: 11Members, Plex Pass Plex Pass
    Pleasure, hope it works for you
  • jamjam Plex Dev Team Posts: 4,303Members, Plex Employee, Plex Pass, Plex Ninja Plex Employee
    If your server is showing as "Unauthorized", it means that the account you're signed into on iOS doesn't have permission to access it. Make sure you're signed into the same account on both, or have shared your server with the account you're using on iOS.
  • George McFlyGeorge McFly Posts: 12Members, Plex Pass Plex Pass
    This is driving me insane. I've never had ANY ISSUES WHATSOEVER with Plex. Now I can NEVER, EVER join the server on my iPad. It always says 'Plex Server - Unauthorised'. I shouldn't need to uninstall and reinstall everything as some people above have suggested. I am paying for a WORKING APP.
    My iPad and server are on the same WIFI network.
    My 'Secure connections' is 'Disabled'. (I've tried 'enabled' too).
    'List of IP addresses and networks that are allowed without auth' - I have added my iPad IP address.
    What more is there left to do to make this work?
  • derick.catman@gmail.comderick.catman@gmail.com Posts: 5Members, Plex Pass Plex Pass
    I just had this issue and it turned out that the Date/Time on the server was not accurate. Thankfully I have a super-SysAdmin brother who caught the issue and corrected the time. Rebooted the server and everything went back to normal.
    CHECK YOUR DATE/TIME before anything else!!!
  • jahowell66jahowell66 Posts: 2Members
    I had this same problem and the problem turned out to be a setting in the Plex server settings. Go into the Plex server portal and choose Settings, then click the Network settings/tab and choose to Show Advanced. Scroll down to the option for "List of IP addresses and networks that are allowed without auth" and enter the subnet that is used on your home network. I had upgraded my wireless router and it changed from 192.168.0.0 to 192.168.151.0. So I changed the setting in Plex to allow: 192.168.0.0/255.255.0.0 and it resolved the problem.
    To find out what your IP subnet is you can go to the CMD prompt in Windows (Click Start, Run and type CMD and hit enter; or use the Windows Key + R and type CMD and hit enter). Then type ipconfig. Look for your IPv4 Address and your subnet mak and you can use those or if they are set to something like 192.168.0.1 you can enter 192.168.0.0 with a subnet mask of 255.255.0.0, Enter it like this in the "List of IP addresses and networks that are allowed without auth" option field: 192.168.0.0/255.255.0.0
  • mytv12590mytv12590 Posts: 1Members
    I had issue in windows 10
    we failed to reach a server reason: unauthorized
    Open regedit and navigate to Computer\HKEY_CURRENT_USER\Software\Plex, Inc.\Plex Media Server
    Create a new string value entry
    I added a string secureConnections
    with value 192.168.1.0/255.255.255.0
    fixed the issue
    other variables are listed here
    https://support.plex.tv/hc/en-us/articles/201105343-Advanced-Hidden-Server-Settings
  • cotsenmoyercotsenmoyer Posts: 1Members, Plex Pass
    I had this issue after upgrading to the Eero mesh router system. The PMS was looking for a device I had renamed (an Apple TV). Trying to connect on that device was not working, but it wasn't obvious what the issue was. After deleting that device from the PMS, restarting the Plex app, and logging out on the Apple TV, I was able to get right back in.
  • bigspeen3436bigspeen3436 Posts: 2Members
    Thanks for posting this! Took just a minute to add my iPhone's IP and subnet mask and it instantly fixed the issue for me.
  • Lord Plexington the ThirdLord Plexington the Third Posts: 1Members, Plex Pass Plex Pass
    Thank you for this, worked a charm for me!
    Hadn't changed any settings and this error pops up for no apparent reason on the iPad after being the only device that worked through about 7 reinstalls.
  • vincentjohnn.vg@gmail.comvincentjohnn.vg@gmail.com Posts: 6Members ✭✭
    Per quanto riguarda i log, i log sono questi(ho preso i log proprio quando facevo l'aggiornamento dei meta-dati per vede cosa faceva, e ho potuto notare uno strano errore http 401):
    "unified_log_plex.log" Sono i log proprio di plex
    "service_log_plex.log" è lo stato del servizio di linux (service plexmediaserver status) e ho catturato lo stato proprio quando faccio l'aggiornamento dei meta-dati, mostrandomi un qualcosa di strano)
    In poche parole è come se non riuscisse a passare alla variabile il nome del film in questione..almeno per come la penso io; un po di basi di programmazione le ho ;)
    Comunque lascio a voi guardare.
    Vi prego, dategli un'occhiata.
    Grazie
