Rasta sitting on top of thewide screen TV
jwaltrip4jwaltrip4 Posts: 592Members, Plex Pass Plex Pass
Rasta balancing on top of the TV
Not to be outdone, Bella on top of the TV too....
Comments
  • lukyjaylukyjay Posts: 8Members, Plex Pass Plex Pass
    They're both judging you haha :)
  • jwaltrip4jwaltrip4 Posts: 592Members, Plex Pass Plex Pass
    Very likely......
  • OttoKernerOttoKerner Posts: 30,166Members, Plex Pass, Plex Ninja Plex Ninja
    With such a name, I expected her to look more like this:
    Got help? Help others too - by reporting back with your results!
    Have you checked the Documentation before posting a question in the forums?
    Use the SEARCH function before starting a new thread!
    No PMs unless requested, please! Do not use 'verbose' logging
    Her full name is Rastafarian....:)
  • cloinkcloink Posts: 15Members, Plex Pass Plex Pass
    No risk of the tv toppling over? :-O
    Rasta weighs about 8 lbs, Bela about 5
    TV is about 80-90 lbs.... Tv does not even shake.
    I also have 2 shelf rails mounted on the back (where the wall hanging screws go), and have a wire frame shelf mounted on the back of the TV. That is what the center channel speaker you see is mounted. The whole rig is placed flush with the wall. While it is not mounted to the wall, since it is in contact it stabilizes everything,.
