TV Shows : No cover art
XireCreativeXireCreative Posts: 2Members Plex Pass
I launch Plex Server and add my tv shows which located on my NAS, everything went well but I do not have the covers of the series but for movies it works ...
Best Answer
«1
Answers
  • SsaulsbuSsaulsbu Posts: 10Members ✭✭
    I have the same issue. No cover art is showing up for any of my media. They've all matched, but all images are a no-go.
  • louisetienneblouisetienneb Posts: 28Members, Plex Pass Plex Pass
    I have the same issue but only for some tv shows...
  • EkomaxEkomax Posts: 300Members, Plex Pass Plex Pass
    Same here -only with Arrow.
    Weird, arrow is one of them for me
  • antonispgsantonispgs Posts: 6Members, Plex Pass Plex Pass
    Me too for most tv shows, if not all.
  • Sp0KISp0KI Posts: 5Members ✭✭
    Yes, same ´problem. No issues on my PC with the same files.
    I removed and re-added the libraries, but this time after scraping, it only picked up about half of the posters.
  • DievilDievil Posts: 2Members
    Hello just wanted to add my voice to this issue. Some of my shows doesn't have any artwork. And if I try to edit the cover art no images are found via tvdb.
  • eug7eug7 Posts: 191Members, Plex Pass Plex Pass
    Shut down my PC base server yesterday and installed Shield server (16GB with 64GB SD card class 10 expansion). Same here. 80-90% missing as opposed to the PC server that in the past when created had 95% or more cover art creation.
  • kegobeer-plexkegobeer-plex Posts: 5,875Members, Plex Pass, Plex Ninja Plex Ninja
    Have you reviewed your agent settings and make sure they match the settings you use on your main Plex server?
    Where are my log files?
    How do I properly name my media files?
    Plex Dance
    NVIDIA SHIELD SMB/NAS Sharing How-To - / - NVIDIA SHIELD Support Documents
    Plex Server: Running on ThinkServer TS140 w/Server 2012 R2 Essentials
    Primary Plex Player: Shield TV, always the latest beta build, always the latest firmware revision
  • amcfarlaamcfarla Posts: 67Members, Plex Pass Plex Pass
    edited June 2016
    @XireCreative said:
    I found the solution. The TVDB doesn't work.
    Solution :
    1/ Edit your library, advanced and choose Movie Database.
    2/ Param > Server > Agents > TV Shows :
    - Tab "TheTVDB" : ascend "The Movie Database" on the first place and check it
    - Tab "The Movie Database" : ascend "The Movie Database" on the first place and check it
    3/ "Refresh all" the library
    I can't check the 'The Movie Database' under shows, I check it, and then go to another area, come back and it isn't checked anymore.
    I am also having the same problem, out of 313 shows, I only have like 40 that have metadata info.
    edited June 2016
    Just grab The Movie Database and put it at the top. If you go to another settings page and come back it should still be at the top. After moving it, click the gear icon and check the first option and save it. The check mark will only stay for the default agent, which is The TVDB. Look at the other agent tabs and you'll see the same behavior.
    Plex Dance
    edited June 2016
    Hmm, this could be the reason we are not getting all the metadata if you are using the 16gb version of the Nvidia Shield TV (https://www.reddit.com/r/AndroidTV/comments/4qfl8j/shield_tv_32_update_qa/d4sj7e5) . May want to see where you are storage wise, it looks like it will not use merged memory to store the thumbnails.
    Yeah, looking at the storage, my microSD card doesn't have really much more used than it did before scanning my media in, but my internal storage is still trying to calculate after at least 15 minutes. If you own the 16GB Nvidia Shield TV, I don't think Plex Media Server will be an option for you unless you have very few media files to serve.
    It's been suggested to the devs to allow Plex data to be stored on the extended internal storage.
    Plex Dance
    MovieDB yields mores results but come up short some. I have multiple movie libraries that seems to be working as expected. I created movie libraries prior to the TV shows. A storage issue might have shown there but has not.
  • DThor2DThor2 Posts: 2Members, Plex Pass Plex Pass
    Thanks for this - my problem had been I was getting series info, but not episode descriptions - I pushed Movies to the top in both the library and agent settings, refreshed and boom, all the love downloaded. I got one show being misinterpreted, but I can live with that. My other problem is that albums have no info either, going to poke around that.
  • vanagandrvanagandr Posts: 9Members, Plex Pass Plex Pass
    I had exactly the same problem with a Mac Mini running Plex Server 0.9.17.2 (there is a thread for this in the Plex Media Server Preview Releases section). The bug disappeared after updating to release 1.0. So perhaps it will be the same here once 1.0 is out for the Shield TV.
    This is still an issue.
«1
