HiFiBerry Digi+ on RasPlex
booleanboolean Posts: 12Members, Plex Pass Plex Pass
I was wondering if someone managed to get their HiFiBerry Digi+ working on RasPlex. It is working on both OpenELEC 5 and 6 by only adding these lines:
dtoverlay=hifiberry-digi
dtdebug=1
When I add these lines one RasPlex, HiFiBerry is selectable from the setting menu. However, when selected the GUI freezes and a hard reboot is needed to bring it back form the dead.
Best Answer
Answers
  • dawtmaytrikxdawtmaytrikx Posts: 10Members, Plex Pass Plex Pass
    Yep, it works fine with my RasPi 2. The sound will drop for a split second every now and then when I'm using the coax output, but no problems otherwise.
    Have you tried reinstalling RasPlex? That's always fixed any freezes for me.
  • st33lost33lo Posts: 2Members, Plex Pass Plex Pass
    can you pls explain how you managed to get work.
  • jacriderjacrider Posts: 47Members, Plex Pass Plex Pass
    I have it running from my RasPi2 with the Digi+ to my external DAC. Works just as described above.
    I have been using it for a year or so. Flawless. I started using the Coax connection, but recently changed DAC's and now have the optical connection. I have a HifiBerry Amp+ in another room. Works ok, it struggles with some very high resolution recordings. The Digi+ has never stuttered or anything. I am using hardwire connections for both.
    I would re-install Rasplex. The setup information on the HifiBerry site is helpful.
  • booleanboolean Posts: 12Members, Plex Pass Plex Pass
    @Admin-Schugart said:
    Hello Bolean
    I don't know if you found the answer...
    But initialy a had the same probleme as you.
    The answer is in the config file comment
    You have to comment the line :
    "# dtoverlay=lirc-rpi "
    And it work fine !
    Apparently this was only needed for the Pi3 (which I have) and it worked indeed! I've switched tot an Odroid C2 a while back, but I had to see if your solution actually worked, and it did!
