Plex on Android TV plays only sound but no picture
Plex client on my Android TV (Philips 55PUS6561) plays only the sound but no picture. I tried to optimize the file and after converting to MP4 plays video and audio. When I try to play the same file via DLNA everything works without conversion. Does anyone have any idea what could be the problem?
Best Answer
Answers
  • mimagyarmimagyar Posts: 3Members ✭✭
    Thank you very much for the advice. Works as it should.
  • davebaridavebari Posts: 15Members ✭✭
    This workaround stopped working for me after latest update. Any suggestion why?
  • davor.varga@gmail.comdavor.varga@gmail.com Posts: 7Members ✭✭
    You are right, it stoped for me too.
    When you go fast forward it frezese the video frame but the sound goes on for few seconds (5-7)
    Maybe we will finally get the right solution for our problem with plex and philips "andorid tv" because passtrough solution was just a quick but wrong fix.
    Our (Philips xxPUSxxxx) tvs should be able to DIRECT PLAY almost everything. Like samsung.
  • gvperkinsgvperkins Posts: 10Members, Plex Pass Plex Pass
    edited February 2017
    Im having the exact same issue now, its all be working fine until this week, I have tried all combination of settings and nothing seems to work. But the same files work on my roku,Ipad and firestick. Seems to be an issue with the Android client. Any one have any further suggestions?
    update, very odd but I can seem to cast same videos without issue????
    Someone tried to contact Plex support?
  • Magic_435Magic_435 Posts: 6Members ✭✭
    I have the same issue, i can play files with DTS and then Plex is transcodeing the file and i got video.
    i wasn't able to force transcoding AC3 as well.
  • kurokuro Posts: 9Members ✭✭
    Same here, everything was working fine and now there's a ton of files I can't play anymore. I reinstalled plexmediaserver and plex but it didn't work.
  • cardrigarcardrigar Posts: 3Members
    Actually as stated by most users with the same problem, only files with AC3 doesn't work. There's no response from either Philips nor Plex staff about the issue...some ppl had the problem for about six months already...
  • drmontydrmonty Posts: 32Members, Plex Pass Plex Pass
    I'm having the same issue, for the time beeing (until this issue get's fixed), I've slightly modified the Android.xml-Profile in Plex Media Server this way:
    <?xml version="1.0" encoding="utf-8"?>
    <Client name="Android">
      <!-- Author: Plex Inc. -->
      <TranscodeTargets>
        <VideoProfile protocol="hls" container="mpegts" codec="h264" audioCodec="aac" context="streaming" />
        <VideoProfile container="mp4" codec="h264" audioCodec="aac" context="static" />
        <MusicProfile container="mp3" codec="mp3" id="StereoMusicTranscodeProfile" />
        <PhotoProfile container="jpeg" />
      </TranscodeTargets>
      <DirectPlayProfiles>
        <VideoProfile container="mp4" codec="h264,mpeg4" audioCodec="aac" />
        <MusicProfile container="mp4" codec="aac" />
        <MusicProfile container="mp3" codec="mp3" />
        <MusicProfile container="flac" codec="flac" />
        <MusicProfile container="ogg" codec="vorbis" />
        <PhotoProfile container="jpeg,gif,bmp,png" />
      </DirectPlayProfiles>
      <ContainerProfiles>
        <VideoContainer name="mp4">
          <Limitations>
            <Match name="part.optimizedForStreaming" value="1" />
          </Limitations>
        </VideoContainer>
      </ContainerProfiles>
      <CodecProfiles>
        <VideoCodec name="*">
          <Limitations>
            <UpperBound name="video.width" value="1920" isRequired="true" />
            <UpperBound name="video.height" value="1080" isRequired="true" />
            <NotMatch name="video.anamorphic" value="1" />
          </Limitations>
        </VideoCodec>
        <VideoCodec name="h264">
          <Limitations>
            <Match name="video.profile" list="baseline|main|high" />
          </Limitations>
        </VideoCodec>
        <VideoAudioCodec name="aac">
          <Limitations>
            <UpperBound name="audio.channels" value="2" />
          </Limitations>
        </VideoAudioCodec>
        <VideoAudioCodec name="ac3">
          <Limitations>
            <UpperBound name="audio.bitrate" value="1" />
          </Limitations>
        </VideoAudioCodec>
      </CodecProfiles>
    </Client>
    And disabled Direct Play in Plex for Android. These modifications lead to forced transcode of an AC3-Audio (only). The video itself get's passed through directly - and yes, videos with i.e. AAC-Audio get's still direct played :).
  • jorgen.bergstromjorgen.bergstrom Posts: 9Members, Plex Pass Plex Pass
    edited August 2017
    I am tired of the lack of response from plex. Nothing happens. Plex seems to have full focus on live tv and things that for me is completely useless.
    I went back to Emby. I installed the emby for android tv client. Playback is smooth. No frame skipping or stutter. Also the response in the emby forums is so much better. Agile project model with frequent releases. Same situation with gpu transcoding. Already works in emby while the plex forum thread is a jungle.
  • ipokampoipokampo Posts: 5Members ✭✭
      <TranscodeTargets>
      </TranscodeTargets>
      <ContainerProfiles>
          <Limitations>
          </Limitations>
        </VideoContainer>
      <CodecProfiles>
          <Limitations>
          </Limitations>
        </VideoCodec>
          <Limitations>
          </Limitations>
        </VideoCodec>
          <Limitations>
          </Limitations>
        </VideoAudioCodec>
          <Limitations>
          </Limitations>
        </VideoAudioCodec>
      </CodecProfiles>
    </Client>
    This worked fine until late June, after 6.1.1 upgrade on client these workaround is not working anymore, now all my videos (ac3 5.1 mkv) do not play video anymore only audio, as before this workaround. Please any help is appreciated
    edited August 2017
    After the latest beta update, the workaround with the modified android.xml works for me again, if I lower the maximum h264 level to, in my case 2.0. I haven't tested the different values in more detail. Without modified android.xml or recommended maximum h264 level (5.1), I get the same black screen problem as before.
  • stefanelul2000stefanelul2000 Posts: 2Members Plex Pass
    I'm having the same problem. On some movies the sound works in dd 5.1 but no video this is at the original form. If I choose to lower it down sometimes to 720p because the file doesn't have enough bitrate, sound and video works but because both are now being processed, the sound is no longer in dolby digital, on some movies I can work around this because I can use PCM sound on my audio setup but on some movies it goes in stereo and I can't do anything. I hope that this, somehow, gets solved because it only happens on the Philips Android TV, if I play the same files that manifest a problem on my PS4 they play just fine. Video transcoding and audio direct play. But the app is so ugly on the PS4 compared to the one on the TV. Hope that someone from Plex will respond one day.
  • GewachseneGewachsene Posts: 7Members, Plex Pass Plex Pass
    edited September 2017
    Same issue here with my new Philips 55PUS64something. Audio works but h264 video doesn't. Tried lowering the h264 max level to 2.0 in the plex app, but no joy. This stinks.
    Current workaround is to use Kodi and the (official) Plex addon.
    Edit: a combination of modifying Android.xml and lowering h264 max level to 3.0 or lower does work, indeed.
  • CP&CPCP&CP Posts: 6Members ✭✭
    Similar issues here with Nvidia Shield Pro 2017.
    Just got it and bought a 1-month Plex Pass which I'll now cancel before it renews - perhaps their business model is to get one subscription from everyone on the planet then go and live in a tax haven.
    Many channels don't tune in the video. Getting an EPG is hard work.
    Recording is a total joke. There seems no way to delete anything (you can remove the underlying file but that just leaves the entry in the list of recordings).
    I tried two recordings to test and one froze the video at the start and the other had no video at all (the programme was playing fine before I recorded it).
    Other apps, such as Kodi. Live TV and HDHomerun all work fine with the HD Homerun connect tuners.
    Using external aerial I'm getting signal and symbol strength of 100%, Quality 86% so there should be no issues there.
    HDHomerun do a $35 per year DVR facility (seems to be priced in USD even here in the UK?), does anyone know how they and/or Emby compare in price, quality and support? I don't care about having media on the go, I just want to replace Virgin Tivo in my home.
    BTW - I see people mentioning Plex support, but there seems no way to contact Plex support directly?
    I'm really annoyed since I bought the Pro specifically because it has Plex "integrated" (seems to just mean pre-installed) and there were warnings over using Plex with adopted storage on the 16Gb version. Could have saved £100.
    edited October 2017
    Seems fixed in the latest Android TV 7 update for my 2017 Philips TV.
  • dvdevildvdevil Posts: 4Members ✭✭
    nothing fixed for android tv,back to kodi
