Plex on Shield fails to passthrough multi channel audio (at times)
jomo7jomo7 Posts: 10Members, Plex Pass Plex Pass
Since upgrading to shield's 5.0 experience update I've been having multi channel sound issues with Plex. It fails to pass through multi channel audio and at times I have to exit the app or try other videos before I can get it to work. If I disable passthrough I can get the audio to work but with it enabled nothing works. This happens with any multi-channel audio (AC3 5.1, DTS-HD, DolbyAtmos, etc).
I've added the logs here pastebin.com/T4d2WHgA
Plex Client Version - 5.4.3.131
Plex Server Version (also on Shield) - 1.3.4.3285
Best Answer
Answers
  • jomo7jomo7 Posts: 10Members, Plex Pass Plex Pass
    If it helps, after getting it to work here are the logs pastebin.com/VA1jsEwY
    Thanks for that. Hopefully this comes out soon.
  • plexapp@sully.orgplexapp@sully.org Posts: 43Members, Plex Pass Plex Pass
    edited February 2017
    I'm running into this as well, with multi-channel FLAC files. How does one (Plex Pass member) get a Android TV / Shield beta build?
  • kegobeer-plexkegobeer-plex Posts: 5,866Members, Plex Pass, Plex Ninja Plex Ninja
    You join the beta program.
    https://forums.plex.tv/discussion/220582/help-us-beta-test-the-android-app#latest
    Where are my log files?
    How do I properly name my media files?
    Plex Dance
    NVIDIA SHIELD SMB/NAS Sharing How-To - / - NVIDIA SHIELD Support Documents
    Plex Server: Running on ThinkServer TS140 w/Server 2012 R2 Essentials
    Primary Plex Player: Shield TV, always the latest beta build, always the latest firmware revision
  • citrusfizzcitrusfizz Posts: 4Members, Plex Pass Plex Pass
    Just tried Plex on shield tv 2nd gen today. updated everything. audio passthrough works except for DTSMA 7.1 or 6.1
    signed up for the beta program, but i only have 14 days to return this device
    Update!!! Success.
    I sideloaded this APK on my shield, now DTS-HD DMA 7.1 chan works!!!
  • Nicolai & KarinaNicolai & Karina Posts: 15Members, Plex Pass Plex Pass
    Will it passthrough any formats now - like Atmos and DTS-HD MA?
    I currently have a Sony Android TV and the only sound Plex will give me is DD or PCM and it transcodes almost all audio codecs.
  • AndrroidAndrroid Posts: 1,140Members, Plex Pass Plex Pass
    Your TV likely does not support Atmos or DTS-HDMA decoding or passthrough.
  • MediaHorderMediaHorder Posts: 3,262Members, Plex Pass Plex Pass
    Unless you have an avr, this will likely always be the case. TV's don't tend to support HD audio passthrough.
    Mac Mini (2.7GHz, Late 2012, Windows 10, Kodi DSPlayer) | SATV 16GB | Panasonic TX-P50GT50B | Yamaha RX-V675 | Q Acoustics 2010i (FL, FR, Left S, Right S), Q2000ci Center, Q2070si Sub
    I have a Sony KDL-55W809C tv and a Sony STR-DN1060 reciever. The plan is to connect the Shield directly to my AMP to benefit the lossless audio.
    ARC only supports LPCM stereo, DTS 3/2.1 and Dolby Digital 3/2.1 anyway, so connecting it to the tv first would just be stupid..
