Audio flutter on Roku 3 and Streaming Stick
brian@tripleswan.combrian@tripleswan.com Posts: 3Members, Plex Pass Plex Pass
Lately, within the last month or two I think, I have been getting an audio flutter from videos played on both Roku 3 and Roku Stream Stick. The audio codec doesn't seem to matter. It happens both with DTS 5.1 and AC3 2.0. Some videos are worse than others (some are horrible). It does not appear to happen on Roku 4 and Netflix is not affected. I have installed the Samsung Plex app on the same TV and the same files are clear.
Was there a recent Plex update that would be causing this? Any suggestions?
Answers
  • kd6iczkd6icz Posts: 345Members, Plex Pass Plex Pass
    I gave my Roku 3 to my dad and he has this issue. His setup is kinda wonky though. Rouk 3 to a Sharp TV then optical digital output to an Onkyo AVR running in 2 channel stereo.
    Not using the Classic version of the app but still does it on the regular Plex app and its annoying.
    Home built Supermicro X99 motherboard with Intel i7-6950x with all 10 cores locked at 4GHz! Each thread scoring 2500 passmark with 128GB 3300 DDR4 and 10Gbps Intel SFP+ NIC. Files stored on QNAP TS-1635 NAS with twelve 6TB WD Reds in RAID6!
