Shuffle not working with Plex 2.006 and now with 2.007 on Samsung ue48h6400
Hello, Shuffle not working with Plex 2.006 and now with 2.007 on Samsung ue48h6400. It is very helpful in series and home videos, but after 2.005 the loading circle continuously spins. Have tried uninstall-reinstall, play one and then play all but nada...
Thanks in advance.
Comments
  • jokarapjokarap Posts: 5Members ✭✭
    Thanks in advance.
    I am sorry. My TV in question is UE48HU7500
  • OrcaOrca Plex for Samsung Developer Posts: 7,515Members, Plex Pass, Plex Ninja Plex Ninja
    Are you sure it's shuffling that is causing the problem?
    Do these episodes play on their one when started separately?
    Which PMS server and what version are you using?
    Have you checked if your answer might be in the User Manual?
    My Samsung environment:
    2010 BD-C5500 Blu-Ray,
    2011 UE46D7000 LED-TV,
    2012 BD-ES6000 Blu-Ray,
    2014 UE55HU8500L UHD LED TV
    If you enjoy this free app, you can buy me a beer by making a Donation
    I am using Plex PMS for Windows 7 64bit version 1.3.4.3285.
    Play all and Shuffle working on my UE32F5000 (plex 2.005)
    But not on my UE48HU7500 since version 2.006 .Now updated to 2.007 but still not working. Shows only the 3 dots loading eternally in the upper left corner. And yes, i can play anything one by one.
  • GrizrazGrizraz Posts: 2Members
    Has there been a resolution to this issue? I'm experiencing the same problem on a similar model Samsung TV. Our Roku has no problem playing all or shuffle playback.
    Version 2.008 is still in testing. I did some fixes. You should try after that one is released.
    Thanks Orca, looking forward to it
    Shuffling issues fixed with 2.009. Thanks Orca!
