[BUG PS4] Mono Audio - No Audio
TheDarkLordDarkTimesTheDarkLordDarkTimes Posts: 14Members, Plex Pass Plex Pass
edited February 15 in PlayStation
I have some tv series that contains Mono that will not play with the show in PlayStation Plex.
One show I currently know that I would like to watch with my ps4 in the current room doesn't work on the system.
Mono AC3
Tested & works with Plex App on these Devices of what I currently have.
-FireTV Stick 1G
-iPod 6G
-Android Nook
-including Web Version (OS X/Windows)
1min video. pswd: plex
http://dai.ly/x5bsyha
Logs: DropBox
Each time I try making a sample, I get this error.
https://s28.postimg.org/pmecukbul/image.png
Got the pic above to work but same errors and my video plays constant freezing, skipping frames, which still end up audio not working in ps4.
Here is a 1min intro sample by mkvtool
DropBox
Here's is the CMD Generating the Sample 2min - which made the show very slugish/skipping frames, if i did it correctly, 1st file is skipping this Generating Sample
DropBox
Answers
  • lederermclederermc Posts: 92Members ✭✭
    Does the media play locally on your Mac's Plex web interface?
  • TheDarkLordDarkTimesTheDarkLordDarkTimes Posts: 14Members, Plex Pass Plex Pass
    Yes, plays fine Locally and in web version.
    pswd: plex
    Just Playstation Plex doesn't work, was gonna watch with my family but end up as a bit of a disaster and did other things.
    PS4 & PS4 Pro, same results, mono does not work.
    edited February 14
    I get wrong password error our upload video
    I don't think AC3 MONO is a common audio format. Do you any other Any other AC3 mono files that do work? I suggest:
    1) can you give it a try on another Plex client that's not PS* such as an iPhone, Android anything, Roku or Amazon Fire anything.
    2) Assuming the video codec is not strange. Try converting one show to AC3 stereo to see if that's the problem. Most of my videos are AAC Stereo (default) plus AC3 5.1 which is what iTunes/Apple TV prefers.
    Let me add, I just ran an AC3 mono/Stereo test on a MacMini serve ring to a Samsung TV App Plex client and to works for me... not that it helps you any.
    I've checked the link 3x, and just now, all lower case letters: plex
    No spaces.
    I have plex on my iPod 6gen and Amazon Fire Stick 1Gen and the audio works fine.
    The ps4 doesn't work.
    Do you any other AC3 mono files that do work on PS4?
    Not sure, now thinking about it, out of 533 tv series (35,000+ episodes), I'm not sure what the other ones are but I know I have some do have mono than a normal typical stereo.
    Shouldn't matter if its mono, all other devices work with plex app except for ps4, meaning it needs an update through ps4 if all the other plex app works.
    If you put one of these nonworking mono AC3 files on a thumb drive then can you play it on the PS4 not using Plex?
    Regardless, a default app from a company, in this case, Playstation, Doesn't fully support all codecs, Not all shows/movie will work with that (Companies) app.
    Ever used a Playstation 3 for videos without being jailbroken? May I need to say more to that?
  • Chris CChris C Posts: 11,811Members, Plex Employee, Plex Pass, Plex Ninja Plex Employee
    Thanks for the report and for including the logs and sample file. We've been investigating possible issues with "mono AC3" streams and I'll be sure to add your information to help that investigation. No specific details to share right now, though.
    (I'm also going to move this topic over to the PlayStation app forum/category, since this is really about the app and not server.)
    Need help? Having trouble?
    » Visit our Support Site for documentation, guides, and more - including the Getting Started section!
    » Attach Log Files when reporting issues // See how to attach files in the forums
    » Name and Organize your content correctly for best results
    (no private messages for support unless requested, please)
    http://manuals.playstation.net/document/en/ps4/music/mp_format_m.html
    Never ever used any PS. Link tells you what is supported out of the box. Your AC3 might be screwy or the PS4 might be broken. I'm just sayings you can test for this.
    edited February 15
    Thank You so much, Didn't know this have been a known issue and thank goodness it wasn't.
    if i did it correctly, 1st file is skipping this CMD Generating Sample and just used mktoolnix
    DropBox
    I do have to say this though, I have a Jailbroken PS3, Plays both audio's perfectly but bc the PS3 was made in 2006, the CPU can't keep up encoding the video, its very slow, Audio had the thunder and lightning when the Video were showing them still at the docks getting to the boat.
    Like Chris says, They have been investigating the issue. So meaning, its not the systems being broken, and not just mine and everyone's ps4's isn't broken. Like I said, A BUG that needs investigating.
  • anzaxanzax Posts: 27Members ✭✭
    im still having this issue, really want to watch some old classics, been waiting almost a year for this to be addressed
  • gtosnipeygtosnipey Posts: 39Validating, Plex Pass Plex Pass
    We have a thread going about the audio issues since the PS4 v1.02 upgrade. We heard back from someone from the Plex team once and haven't heard since. Have been following up again and again PS4 v4.72 & Plex v1.02
