Our forum migration to Discourse is underway and scheduled to last through June 21. During the migration, the forums will be read-only, except for a single temporary forum (contents of which will not be getting transferred). Read our announcement post for more information about the forum migration.
Hey folks, there is a new Podcast category for forums https://forums.plex.tv/categories/podcasts
RARFlix crash on startup with PMS 1.4+ (with fix included, please read)
iaddisiaddis Members, Plex Pass Posts: 4 Plex Pass
edited March 2017 in Plex Classic for Roku
I tracked this down to the fetching of active sessions through this url: /status/sessions
Apparently RARFlix expects there to be a valid key attribute in each Part from this request, else it will crash when building URLs. This is not a problem with PMS 1.3.4.3285 which always provides a key.
There is a simple one line fix in the RARFlix client to avoid this crash. But it would be better to have PMS provide a key even if its empty string. One also potential workaround is to disable 'now playing' on the home screen in the rarflix preferences (have to restart PMS to get there the first time).
Here is the XML:
Brightscript Debugger> p MediaPart.GenXML(true)
    <?xml version="1.0" encoding="UTF-8"?><Part width="720" protocol="hls" bitrate="2079" audioProfile="dts" decision="transcode" duration="2629547" container="mpegts" height="406" id="1016959" selected="1" videoProfile="high" indexes="sd"><Stream width="720" codec="h264" bitrate="1500" decision="transcode" duration="2629546" default="1" height="406" frameRate="23.975999999999999" streamType="1" id="2119992" /><Stream codec="ac3" bitrate="579" language="English" channels="6" decision="transcode" duration="2629547" default="1" bitrateMode="cbr" streamType="2" id="2119993" selected="1" languageCode="eng" /></Part>
Here is fix although good luck getting rarflix updated (?):
 Plex/source/PlexMediaServer.brs | 4 ++++
 1 file changed, 4 insertions(+)
diff --git a/Plex/source/PlexMediaServer.brs b/Plex/source/PlexMediaServer.brs
index 16416db..a1a68e4 100644
--- a/Plex/source/PlexMediaServer.brs
+++ b/Plex/source/PlexMediaServer.brs
@@ -535,6 +535,10 @@ End Function
 '* relative to the server URL
 Function FullUrl(serverUrl, sourceUrl, key) As String
     finalUrl = ""
+    if key = invalid then
+        key = "" ' fix for session results on later plex servers >=1.4 which sometimes return no key
+    endif
     if left(key, 4) = "http" OR left(key, 4) = "rtmp" or left(key, 3) = "mms" or left(key, 4) = "rtsp" then
         return key
     else if left(key, 4) = "plex" then
