Issue with slash symbol in @route declaration
CigarasCigaras Posts: 125Members ✭✭
edited March 2017 in Channel Plugin Development
I have an issue with dynamic @route declaration:
@handler('test')
def MainMenu():
    oc = ObjectContainer()
    group = Prefs['group'] # for example aaa/bbb
    oc.add(DirectoryObject(key = Callback(ListItems, group = unicode(group)), title = group))
    return oc
@route('test/listitems/{group}', page = int)
def ListItems(group, page = 1):
    items = Dict[group]
    for item in items:
I get an error stating that url test/listitems/aaa/bbb is not found, how can I escape it to something like test/listitems/aaa&#47bbb or similar? aaa/bbb value is being red from preferences, provided by user.
If I drop the {group} from @route I see this in log file:
DEBUG (runtime:717) - Handling request GET /video/iptv/listitems?group=aaa%2Fbbb
So Plex is able to change / to %2F in some situations, I want to force Plex to do so in @route, so I could get this:
DEBUG (runtime:717) - Handling request GET /video/iptv/listitems/aaa%2Fbbb
P. S. On one hand omitting the {group} might be a solution, but if group text has unicode symbols the "unicodeness" is lost when passing group as a parameter to a procedure and group is not a part of a @route, but this is a different question.
Best Answer
Answers
  • TwoureTwoure Posts: 583Members ✭✭✭
    Maybe:
    # Encode with Plex's custom base64 Encode/Decode
    group = E(Prefs['group'])
    # then when you need it later
    items = Dict[D(group)]
    E() and D() are aliases for Encode() and Decode() respectively.
    Info taken from utilkit.py:
    def Encode(s):
            Encodes the given string using the framework's standard encoding (a slight variant on
            Base64 which ensures that the string can be safely used as part of a URL).
    def Decode(self, s):
            Decodes a string previously encoded using the above function.
  • CigarasCigaras Posts: 125Members ✭✭
    edited March 2017
  • sander1sander1 Channel Developer/Admin Posts: 3,735Members, Plex Pass, Plex Ninja Plex Ninja
    GET parameters are automatically encoded into a safe string. When you create a route, you have to do that yourself. The solution is mentioned by dane22 above.
  • dein0sdein0s Posts: 8Members ✭✭
    Speaking of the latest public server (1.4.4.3495) with corresponding framework - String.Quote() from utilskit.py wouldn't help with this issue.
    Why? Because you can't pass any **kwargs to it and urllib.quote() by default does not encode / symbol as it's marked as safe (ref to https://docs.python.org/2/library/urllib.html#urllib.quote).
    But, you can import it directly and use like this:
    from urllib import quote
    some_unsafe_string = '/this/is/unsafe/string'
    safe_string = quote(some_unsafe_string, safe='')
