TV Mode not utilizing immersive mode [bugfix]
Eldon McGuinnessEldon McGuinness Posts: 141Members, Plex Pass Plex Pass
Would love to see the app use immersive mode when available. The way it is currently, it leaves the soft-buttons on the screen until something is played. This leads to information being blocked by said soft-buttons area.
Answers
  • MovieFan.PlexMovieFan.Plex Posts: 16,696Members, Plex Pass, Plex Ninja Plex Employee
    What device are you using? If there are soft buttons, you shouldn't be able to use TV Mode.
  • Eldon McGuinnessEldon McGuinness Posts: 141Members, Plex Pass Plex Pass
    edited March 2017
    @MovieFan.Plex This is an OUYA device that has Cyanogen 4.4.4 on it. While I could use Xposed to hide the soft buttons, it would be a better fix if the app just used immersive mode to ensure it hides things as needed, much like KODI does.
    Perhaps this would be affecting all 4.4+ devices, except for Android TV of course.
    I double checked and the TV Mode should work in full screen mode. It was added back in version 5.3.0. I don't know if running Cyanogen might be making a difference. Can you get me the full details on the ROM? i.e. full Android version number, kernel, etc.
    edited March 2017
    @MovieFan.Plex
    I pulled this from ADB as I am not at the device ATM, please let me know if that is enough information:
    Kernel: Linux version 3.1.10-cyanogenmod-gaec3c7f (jenkins@milaq) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Sat Oct 1 05:38:46 CEST 2016
    Below are the properties available from getprop
    [bluetooth.isEnabled]: [true]
    [dalvik.vm.dexopt-flags]: [m=y]
    [dalvik.vm.heapgrowthlimit]: [64m]
    [dalvik.vm.heapmaxfree]: [8m]
    [dalvik.vm.heapminfree]: [512k]
    [dalvik.vm.heapsize]: [384m]
    [dalvik.vm.heapstartsize]: [8m]
    [dalvik.vm.heaptargetutilization]: [0.75]
    [dalvik.vm.lockprof.threshold]: [500]
    [dalvik.vm.stack-trace-file]: [/data/anr/traces.txt]
    [debug.force_rtl]: [0]
    [dev.bootcomplete]: [1]
    [dhcp.eth0.dns1]: [10.0.1.1]
    [dhcp.eth0.dns2]: []
    [dhcp.eth0.dns3]: []
    [dhcp.eth0.dns4]: []
    [dhcp.eth0.domain]: []
    [dhcp.eth0.gateway]: [10.0.1.1]
    [dhcp.eth0.ipaddress]: [10.0.1.22]
    [dhcp.eth0.leasetime]: [86400]
    [dhcp.eth0.mask]: [255.255.255.0]
    [dhcp.eth0.mtu]: []
    [dhcp.eth0.pid]: [505]
    [dhcp.eth0.reason]: [RENEW]
    [dhcp.eth0.result]: [ok]
    [dhcp.eth0.server]: [10.0.1.1]
    [dhcp.eth0.vendorInfo]: []
    [gsm.current.phone-type]: [1]
    [gsm.network.type]: [Unknown]
    [gsm.operator.alpha]: []
    [gsm.operator.iso-country]: []
    [gsm.operator.isroaming]: [false]
    [gsm.operator.numeric]: []
    [gsm.sim.state]: [NOT_READY]
    [init.svc.adbd]: [running]
    [init.svc.auditd]: [running]
    [init.svc.bootanim]: [stopped]
    [init.svc.bt_mac]: [stopped]
    [init.svc.console]: [running]
    [init.svc.debuggerd]: [running]
    [init.svc.dhcpcd_eth0]: [running]
    [init.svc.drm]: [running]
    [init.svc.eth_mac]: [stopped]
    [init.svc.healthd]: [running]
    [init.svc.installd]: [running]
    [init.svc.keystore]: [running]
    [init.svc.media]: [running]
    [init.svc.netd]: [running]
    [init.svc.rm_ts_service]: [restarting]
    [init.svc.sdcard]: [running]
    [init.svc.servicemanager]: [running]
    [init.svc.setup_fs]: [stopped]
    [init.svc.su_daemon]: [running]
    [init.svc.surfaceflinger]: [running]
    [init.svc.sysinit]: [stopped]
    [init.svc.tf_daemon]: [running]
    [init.svc.ueventd]: [running]
    [init.svc.vold]: [running]
    [init.svc.zygote]: [running]
    [keyguard.no_require_sim]: [true]
    [net.bt.name]: [Android]
    [net.change]: [net.dns1]
    [net.dns1]: [10.0.1.1]
    [net.hostname]: [android-745f3117eb179e52]
    [net.qtaguid_enabled]: [1]
    [net.tcp.buffersize.dchspap]: [4094,87380,1220608,4096,16384,1220608]
    [net.tcp.buffersize.default]: [4096,87380,704512,4096,16384,110208]
    [net.tcp.buffersize.edge]: [4093,26280,35040,4096,16384,35040]
    [net.tcp.buffersize.evdo]: [4094,87380,262144,4096,16384,262144]
    [net.tcp.buffersize.evdo_b]: [4096,87380,704512,4096,16384,262144]
    [net.tcp.buffersize.gprs]: [4092,8760,11680,4096,8760,11680]
    [net.tcp.buffersize.hsdpa]: [4094,87380,1220608,4096,16384,1220608]
    [net.tcp.buffersize.hspa]: [4094,87380,1220608,4096,16384,1220608]
    [net.tcp.buffersize.hspap]: [4094,87380,1220608,4096,16384,1220608]
    [net.tcp.buffersize.hsupa]: [4094,87380,1220608,4096,16384,1220608]
    [net.tcp.buffersize.lte]: [524288,1048576,2097152,262144,524288,1048576]
    [net.tcp.buffersize.umts]: [4094,87380,110208,4096,16384,110208]
    [net.tcp.buffersize.wifi]: [524288,1048576,2097152,262144,524288,1048576]
    [net.tcp.default_init_rwnd]: [60]
    [net.tcp.delack.default]: [1]
    [net.tcp.delack.lte]: [8]
    [net.tcp.delack.wifi]: [20]
    [net.tcp.usercfg.default]: [0]
    [net.tcp.usercfg.lte]: [1]
    [net.tcp.usercfg.wifi]: [1]
    [nvcpud.config_refresh_ms]: [-1]
    [nvcpud.enabled]: [true]
    [persist.sys.NV_DISPXRES]: [1920]
    [persist.sys.NV_DISPYRES]: [1080]
    [persist.sys.NV_STEREOAPP]: [0]
    [persist.sys.NV_STEREOCTRL]: [0]
    [persist.sys.dalvik.multithread]: [false]
    [persist.sys.dalvik.vm.lib]: [libdvm.so]
    [persist.sys.dun.override]: [0]
    [persist.sys.profiler_ms]: [0]
    [persist.sys.recovery_update]: [false]
    [persist.sys.root_access]: [3]
    [persist.sys.timezone]: [America/New_York]
    [persist.sys.usb.config]: [mtp,adb]
    [ro.adb.secure]: [1]
    [ro.allow.mock.location]: [0]
    [ro.baseband]: [unknown]
    [ro.board.platform]: [tegra]
    [ro.boot.commchip_id]: [0]
    [ro.boot.emmc]: [0]
    [ro.boot.serialno]: [015d483b87082208]
    [ro.bootloader]: [unknown]
    [ro.bootmode]: [unknown]
    [ro.bq.gpu_to_cpu_unsupported]: [1]
    [ro.bt.bdaddr_path]: [/data/misc/bluetooth/bdaddr]
    [ro.build.characteristics]: [tablet]
    [ro.build.date.utc]: [1475292631]
    [ro.build.date]: [Sat Oct  1 05:30:31 CEST 2016]
    [ro.build.description]: [ouya-user 4.4.2 KOT49H 937116 release-keys]
    [ro.build.display.id]: [cm_ouya-userdebug 4.4.4 KTU84Q b53c81a5ef test-keys]
    [ro.build.fingerprint]: [boxer8/ouya/ouya:4.4.2/KOT49H/937116:user/release-keys]
    [ro.build.host]: [milaq]
    [ro.build.id]: [KTU84Q]
    [ro.build.product]: [ouya]
    [ro.build.selinux]: [1]
    [ro.build.tags]: [test-keys]
    [ro.build.type]: [userdebug]
    [ro.build.user]: [jenkins]
    [ro.build.version.base_os]: []
    [ro.build.version.codename]: [REL]
    [ro.build.version.incremental]: [b53c81a5ef]
    [ro.build.version.release]: [4.4.4]
    [ro.build.version.sdk]: [19]
    [ro.build.version.security_patch]: [2016-08-01]
    [ro.carrier]: [wifi-only]
    [ro.cm.device]: [ouya]
    [ro.cm.display.version]: [11-20161001-NIGHTLY-MLQ-ouya]
    [ro.cm.releasetype]: [NIGHTLY]
    [ro.cm.version]: [11-20161001-NIGHTLY-MLQ-ouya]
    [ro.cmlegal.url]: [https://cyngn.com/legal/privacy-policy]
    [ro.com.android.dataroaming]: [false]
    [ro.com.android.dateformat]: [MM-dd-yyyy]
    [ro.com.android.wifi-watchlist]: [GoogleGuest]
    [ro.com.google.clientidbase]: [android-google]
    [ro.config.alarm_alert]: [Hassium.ogg]
    [ro.config.notification_sound]: [Argon.ogg]
    [ro.crypto.fuse_sdcard]: [true]
    [ro.crypto.state]: [unencrypted]
    [ro.crypto.tmpfs_options]: [size=128m,mode=0771,uid=1000,gid=1000]
    [ro.crypto.umount_sd]: [false]
    [ro.cwm.forbid_format]: [/boot]
    [ro.debuggable]: [1]
    [ro.emmc]: [0]
    [ro.factorytest]: [0]
    [ro.hardware]: [cardhu]
    [ro.modversion]: [11-20161001-NIGHTLY-MLQ-ouya]
    [ro.opengles.version]: [131072]
    [ro.product.board]: [cardhu]
    [ro.product.brand]: [Boxer8]
    [ro.product.cpu.abi2]: [armeabi]
    [ro.product.cpu.abi]: [armeabi-v7a]
    [ro.product.device]: [ouya]
    [ro.product.locale.language]: [en]
    [ro.product.locale.region]: [US]
    [ro.product.manufacturer]: [Boxer8]
    [ro.product.model]: [Ouya]
    [ro.product.name]: [ouya]
    [ro.revision]: [0]
    [ro.rommanager.developerid]: [cyanogenmodnightly]
    [ro.runtime.firstboot]: [1489202995792]
    [ro.secure]: [1]
    [ro.serialno]: [015d483b87082208]
    [ro.setupwizard.enterprise_mode]: [1]
    [ro.sf.lcd_density]: [210]
    [ro.url.legal.android_privacy]: [http://www.google.com/intl/%s/mobile/android/basic/privacy.html]
    [ro.url.legal]: [http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html]
    [ro.wifi.channels]: []
    [ro.zygote.disable_gl_preload]: [true]
    [selinux.reload_policy]: [1]
    [service.adb.tcp.port]: [5555]
    [service.bootanim.exit]: [1]
    [sys.boot_completed]: [1]
    [sys.cpufreq.restored]: [true]
    [sys.iosched.restored]: [true]
    [sys.settings_secure_version]: [10]
    [sys.sysctl.extra_free_kbytes]: [24300]
    [sys.sysctl.tcp_def_init_rwnd]: [60]
    [sys.usb.config]: [mtp,adb]
    [sys.usb.state]: [mtp,adb]
    [tf.enable]: [y]
    [vold.post_fs_data_done]: [1]
    [wifi.interface]: [wlan0]
    [wifi.supplicant_scan_interval]: [15]
    [wlan.driver.status]: [unloaded]
    EDIT:
    For anyone else with this problem, if you don't use the soft-buttons and have a rooted device you can append the following line to your build.prop file to hide them.
    qemu.hw.mainkeys=1
