Plex DVR not recording
asilentnoizeasilentnoize Posts: 4Members, Plex Pass Plex Pass
I am running a plex server on freeNAS 9.10. After setting up my hdhomerun prime I choose a program to record. It shows in the recording schedule but will not start recording. There are no error messages. I decided to setup a plex server on my windows machine. Everything works fine on it... any clue what could be going on?
«13
Answers
  • Resist2020Resist2020 Posts: 1Validating, Plex Pass Plex Pass
    Same issue.
    The only thing I haven't tried yet is to update. Will see if that works.
  • swoop124swoop124 Posts: 20Members, Plex Pass Plex Pass
    Hi guys,
    my plex server is running on a Windows 2012 Server, until now everithing was good. Today i've added a HDHomeRun Expand with 4 DVB-C tuners. I can watch TV with the HDHomeRun-App. But when i add a recording to my list, it looks like if the server recordes but there is no file.
    One spetiality, i have my HDHomeRun on an other subnet then the server.
    Could that be the problem?
    There is no write issue, because the user, plex runs with, could write to the location of the recordings.
    sorry for me bad english :smile:
    hope you could help me.
  • DaddyGoofballDaddyGoofball Posts: 20Members, Plex Pass Plex Pass
    @swoop124 said:
    Hi guys,
    This should be a separate thread.
    HDHomerun devices need to be on the same subnet to be discovered. When using the HDHR utility to watch live TV from my laptop I have trouble watching the devices when on different subnets
    If you are running out of IP space expand your network. Refer to your network equipment manufacturer for information on how to expand your network.
  • nonsensicalnonsensical Posts: 14Members, Plex Pass Plex Pass
    This happens to me as well. Strange thing is most shows record just fine but a few select shows show "successfully recorded" in the Recording Schedule page but they aren't actually anywhere to be found in the directory it supposedly recorded to. This has happened on Plex for Linux (Ubuntu and CentOS) and Plex in FreeBSD. All were setup fresh i.e., no data from another install moved to the next Plex machine.
  • cmpanacmpana Posts: 1Members, Plex Pass Plex Pass
    The same thing is happening to me. I'm using Windows 2012 R2 Server and sometime it records fine and sometimes it shows "successfully recorded" in the recording schedule, but the file is not saved to my hard drive.
  • rkoster25rkoster25 Posts: 1Members, Plex Pass Plex Pass
    I'm running Plex server on a Windows 7 computer with USB storage. About 50% of the time it records and the other 50% it doesn't. Once it appeared to record but when I tried to watch my show, it said the file was corrupt.
  • rhithynrhithyn Posts: 8Members, Plex Pass Plex Pass
    Same problem for me, many recordings are "successfully recorded" but no recording actually available. This has happened on all three different installations I've tried: Ubuntu 17.04, Windows 10 and Mac OS X Sierra.
    It seems "married" to some shows (e.g.: two different home improvement shows set to record anything without restriction will never record for me). I thought it was related to some stations that are intermittent in their signal sometimes, but it will record the next show just fine still showing the signal drops in the recordings.
    One time I saw it "recording" a show, and when the indicator shown it was done recording, it briefly came up with a red exclamation point icon and then changed over to no icon (not even the "play" icon with "Recorded Successfully" as the status in the details.
    This has been happening for me since February.
  • jjabenzajjabenza Posts: 1Members, Plex Pass Plex Pass
    Same to me with Nvidia Shield TV and Haupaugge DVB-T dual card. It only worked the first time
  • adrianwiadrianwi Posts: 264Members, Plex Pass Plex Pass
    On FreeNAS, my guess would be permissions. PMS needs to be able to write to the folder you are saving DVR recordings too. I've created a separate DVR folder in my media dataset, as the movies and TV shows folders have permissions so I can copy across content from my Mac, but these won't allow PMS to save to them.
    SuperMicro X10SL7-F with Intel Xeon E3-1231 and 32GB RAM running FreeNAS 9.10.1-U4 (9x4TB RAID-Z2)
    Running jails for emby (3.2.36.0) and various others (ownCloud, openVPN, unbound, VirtualBox, calibre, WordPress)
    No longer running Plex Media Server or using any Plex Clients :(
    http://aw1.co.uk
  • wannabe1wannabe1 Posts: 5Members Plex Pass
    Has anyone found a solution to this? Latest Plex build with win 10 Pro.
    Shows will record successfully if scheduled from the 'playing now' or 'upcoming' lists, but when I schedule the program to record from using the search bar, it shows recorded but is not in any folder on the drive.
  • johnm_ColaSCjohnm_ColaSC Posts: 1,892Members, Plex Pass, Plex Ninja, TunerTester Plex Ninja
    Anyone looked in their Plex Media Server log file to see if there are any messages indicating a possible reason for the show not appearing?
    Perhaps something like the message below that I found the other night in another users log file:
    Jul 13, 2017 16:29:41.817 [10368] DEBUG - Garbage Collector: Deleting expired unwatched content for The FBI Files (policy: -30 before 2017-06-13)
    Jul 13, 2017 16:29:41.843 [10368] DEBUG - Garbage Collector: Deleting episode 14 - Rebellion in Paradise (beyond window of 30 days old)
    In this users case they had a deletion policy of 30 days on the library show settings. Plex uses the original air date of episodes.
    Primary Plex Media Server
    Windows 10 Pro
    Intel Core i5-3570K, 32GB RAM
    Post Processing with MCEBuddy 2.4.7 & Comskip 0.81.093
    Test Servers: MacBook Pro, Nvidia Shield TV (16GB), Windows Laptop, Ubuntu VM
    HDHR Connect (2), HDHR Dual, HDHR Extend, HDHR Prime
    Clients - Windows, iOS, Roku, Samsung TV, Fire TV, Nvidia Shield
  • kalenxikalenxi Posts: 9Members, Plex Pass Plex Pass
    I just ran into this myself, it was because I misinterpreted the "Keep" setting of the DVR Record Options. I thought setting "Keep" to "Episodes from the past 7 day" meant "Keep episodes that were recorded within the last 7 days", but what it actually means is "Keep episodes that originally aired within the last 7 days". They should probably reword that setting to make it more clear.
  • SirGioSirGio Posts: 74Members, Plex Pass Plex Pass
    edited July 2017
    Same here. Have this issue for a while. And all of my recordings except for local news are set to keep all recordings.
    Mac OS 10 ||| 3 GHz Intel Core i7 ||| 16 GB 1600 MHz DDR3 ||| Intel Iris 1536 MB
    1TB APPLE SSD Internal ||| Media on external USB3 drives ||| HDHomeRun EXTEND
    Clients - AppleTV4, iOS, Roku3
    @SirGio Is the show settings in your library set to keep all? Garbage Collection like the log entries I showed above are looking at the show settings in the library, not the recording settings. Click your library show is being recorded to, click the show, and then click edit and go to the advanced tab.
    Windows 10 Pro
    @johnm_ColaSC I didn't know there were DVR settings at the show level, thanks for that tip, however I checked and all my shows seem to be respecting the initial setup of keeping all episodes and keeping 4 for local news shows.
    I might have a different issue than you however I've found similar reports from other users in this forum and in Reddit but with no definitive resolution other than rolling back to previous versions.
    I have no experience reading the logs. I just downloaded them through the help section in the Plex web app. Can you please advise which file should I look into?
    Plex Media Server log is where to start. Look for anything dealing with the show you are recording. You should be able to see when it starts, then as it is recording Plex will report that it is 1% completed, 2% completed, all the way up to 100% completed. When done recording look for any clues as to if Garbage Collection is running against the show and deleting episodes.
    Windows 10 Pro
    @johnm_ColaSC I was trying to check logs from yesterday but all Plex Media Server log files (1 through 5) had only entries with today's date. Is there a way to access old logs?
    So I decided to schedule a new recording around 15 min ahead of the airing time of a ramdom show and set it to keep all episodes (airing time: 12-12:30pm, name: "Enfoque").
    Since this was a new show never recorded before it did not show up in my DVR library section ahead of the recording, not sure if that's normal behavior.
    Then after the show ended there was no folder created for the show since it did not complete the recording.
    Using TextWrangler I filtered the lines from the log with the show name (see attached)
    The only thing that caught my attention was the following entry that repeats 4 times:
    DEBUG - DVR:Subscription: Failed to resolve subscription for 'guid: com.gracenote.onconnect://show/378222 thumb: http://tmsimg.plex.tv/assets/p378222_b_v8_ac.jpg title: Enfoque type: show year: 2002' to library item
    No way to access old logs, unless you are backing up the log directory several times a day. The logs are cycled through, when the "Plex Media Server.log" fills up:
    "Plex Media Server.5.log" is deleted,
    "Plex Media Server.4.log" is changed to "Plex Media Server.5.log",
    "Plex Media Server.3.log" is changed to "Plex Media Server.4.log",
    "Plex Media Server.2.log" is changed to "Plex Media Server.3.log",
    "Plex Media Server.1.log" is changed to "Plex Media Server.2.log",
    "Plex Media Server.log" is changed to "Plex Media Server.1.log",
    and a new "Plex Media Server.log" file is started.
    There are actually 6 log files being used, the 1-5 you mentioned and one without a number.
    Would probably be helpful to see a full set of logs. You can download all the logs as a zip file by going to Settings/Server/Help and clicking the Download Logs link. Please ensure that Debug logging is turned on, verbose is turned off, and the Allow Plex Media Server tokens in logs is also turned off.
    Windows 10 Pro
    @johnm_ColaSC Thanks! Attaching logs.
    Appears that the recording was successful. Just don't see any entries where it was moved from grab folder or anything after the last entry I have below.
    Jul 23, 2017 12:00:00.349 [0x70000cc82000] DEBUG - DVR:Grabber: Starting operation for 'Enfoque - Episode 07-23'.
    Jul 23, 2017 12:00:00.353 [0x70000cc82000] DEBUG - Activity: registered new activity 601e9463-c411-4d43-86ea-d75f3fdf4946 - Recording
    Jul 23, 2017 12:00:00.353 [0x70000cc82000] DEBUG - DVR:Grabber: HDHomerun starting a media grab on device device://tv.plex.grabbers.hdhomerun/1053D6A7 tuner 0.
    Jul 23, 2017 12:00:00.356 [0x70000cc82000] DEBUG - DVR:Subscription: Failed to resolve subscription for 'guid: com.gracenote.onconnect://show/378222 thumb: http://tmsimg.plex.tv/assets/p378222_b_v8_ac.jpg title: Enfoque type: 2 year: 2002' to library item
    Jul 23, 2017 12:00:00.356 [0x70000cc82000] DEBUG - DVR:Grabber: Saving recording to /Volumes/Tevado/DVR Shows/.grab/c24f6e229523a716811f2fb49eed16fc29a103c6
    Jul 23, 2017 12:00:00.382 [0x70000cc82000] DEBUG - DVR:Grabber: Going to record for 1800 seconds, final URL is http://10.0.1.2:5004/auto/v51.1?transcode=mobile
    Jul 23, 2017 12:00:00.387 [0x70000cc82000] DEBUG - DVR:Grabber: Setting timer to stop grab of 'Enfoque - Episode 07-23' in 1800 seconds.
    Jul 23, 2017 12:30:00.013 [0x70000c970000] DEBUG - DVR:Grabber: Cancelling operation for 'Enfoque - Episode 07-23' with status complete.
    Jul 23, 2017 12:30:00.013 [0x70000c970000] DEBUG - DVR:Grabber: Operation was active, stopping recorder.
    Jul 23, 2017 12:30:02.718 [0x70000ca76000] DEBUG - Activity: updated activity 601e9463-c411-4d43-86ea-d75f3fdf4946 - completed 100% - Recording
    I do see several other transcode sessions with what appears to be playing recorded content and some Live TV going on as well. Wonder if the transcode activity was slowing the recording getting transcoded and moved into the Library. Logs end at 12:31:17 so don't know if anything else was happening with the recording after that point.
    Is the recording still displaying the red circle? There was several reports on the forum regarding recordings that never appeared to end, still had the red circle hours after the recording should have finished. I had one instance myselff. Had to stop/restart Plex Server to get it to quit and then lost the recording after restart.
    Perhaps a Plex Employee can look at your logs and provide some other insight. @keithah @BigWheel
    Windows 10 Pro
«13
