System errors when using Xbox One S client plugin with Freenas Corral
mysticpetemysticpete Posts: 79Members, Plex Pass Plex Pass
Hi
I am continually getting repeated Warnings and Info messages when I use the Plex client on Xbox one S.
Apr 04, 2017 11:48:16.093 [0x7f9578ffe700] WARN - [Plex for Xbox One] [Connections] Prevented fallback to insecure connection for PlexMediaServer
Apr 04, 2017 11:48:20.232 [0x7f95787fd700] INFO - [Plex for Xbox One] [Companion] Poll connection established successfully
Apr 04, 2017 11:48:47.001 [0x7f959fbfe700] WARN - LongPoll: Got error, closing.
Apr 04, 2017 11:48:47.053 [0x7f95787fd700] INFO - [Plex for Xbox One] [Companion] Server PlexMediaServer has had 1 poll errors
Apr 04, 2017 11:48:47.104 [0x7f9578ffe700] WARN - [Plex for Xbox One] [Companion] Poll failed to PlexMediaServer; testing all connections
Apr 04, 2017 11:48:47.717 [0x7f95787fd700] INFO - [Plex for Xbox One] [Companion] Poll failed to PlexMediaServer; server is available
Apr 04, 2017 11:48:47.767 [0x7f95787fd700] WARN - [Plex for Xbox One] [Companion] Poll failed to PlexMediaServer; attempting to pick new proxy
Apr 04, 2017 11:48:47.817 [0x7f9578ffe700] INFO - [Plex for Xbox One] [Companion] Found proxy PlexMediaServer
Apr 04, 2017 11:48:47.867 [0x7f95787fd700] INFO - [Plex for Xbox One] [Companion] Opening long poll to PlexMediaServer at https://192-168-1-1.314119a3c879486394263dee65ad4db5.plex.direct:32400/
Apr 04, 2017 11:48:48.206 [0x7f95787fd700] WARN - [Plex for Xbox One] [Connections] PlexMediaServer is unavailable at https://122-149-236-89.314119a3c879486394263dee65ad4db5.plex.direct:19933/ (Status 0)
ASRock FM2A88X-ITX+ Mini ITX FM2+ Motherboard
AMD A8-7600 3.1GHz Quad-Core OEM/Tray Processor
Cooler Master Hyper 212X 82.9 CFM CPU Cooler
Fractal Design Node 304 Mini ITX Tower Case
5 x 2 TB WD RED NAS
120GB SSD running FreeNAS 10 Corral
Dockers:
PLEX Media Server
Transmission
Clients:
Astone MP-310DT
XBox One S
Yamaha A3079 Receiver
Yamaha A1040 DVD Media streamer
ROKU Stick (PlexPass Version)
Bauhn 65" LED TV
Best Answer
Answers
  • kylevkylev Posts: 4Members, Plex Pass Plex Pass
    edited April 2017
    @Moussa said:
    Hi there. Those messages are harmless, you can ignore them :smile:
    This is way too chatty (every 30 seconds), categorically worrying (WARN), and harshly worded ("LongPoll: Got error, closing.") for a reasonable system administrator to ignore. :blush:
    I'm not saying you're wrong, I'm saying you have a "user interface" type of bug. Anyone troubleshooting an actual problem may be mislead by spurious logging, so a little tidying up here would be nice.
    Also, it might be nice to have a valid SSL certificate and an informational page at https://plex.direct/ since that domain will be all over logs. :wink:
