Synced smart playlist (track rating) are not working on iOS
YendiYendi Posts: 139Members, Plex Pass Plex Pass
edited May 2017 in iOS
As I have "isolated" the bug I edit my first post and title for clarity:
There is a glitch with how Plex handle smart playlist filtered by the track rating.
All my smart playlist that have a filter with track rating are not working on iOS: I have them synced but I can not open them (infinite rotating wheel).
I have found that the songs are not the cause as I can listen to the same song in a regular synced playlist
I can also listen to the smart playlist when streamed
Smart playlist that do not have track rating filter are fine too.
OLD POST:
Hello,
I just rebuilded a new plex server from the ground up on a dedicated i7 PC.
After importing all my media and analysed them I synced some smart playlist (> 4* and > 2*) to my phone.
The sync starts but always finish with errors (on the same songs but those songs are perfectly fine and playable thru Plex web and in streaming).
I tried with a different quality setting so they get reencoded but same issue.
This could be okay as it is only few songs but then, on iOS I select my "phone server" to get the synced playlist, and there is just an infinite rotating wheel (loading) for local synced playlist (it never loads).
--> If I select my server and the same playlist on the same phone, it loads fine and I am able to listen to all music in streaming.
At the end, the only way to listen to my music is to stream as I am completely unable to sync.
I tried to delete and reinstall the app, no change.
Running on iOS 10.3.1 no jailbreak or whatsover.
Pictures of the issue: https://imgur.com/a/5YhyV
1st : infinite loading when I try to access a synced playlist
2nd : Errors that I have when I try to sync playlists.
Edited by sa2000 to make links visible as links
«1
Answers
  • YendiYendi Posts: 139Members, Plex Pass Plex Pass
    Added picture of my bug
    edited April 2017
    So I made a lot of tests:
    The issue with corrupted files is solved, I only had to analyse all media again, however I an still unable to listen to ANY smart playlist on iOS: I just have the loading wheel.
    I can sync the smart playlist but I can't use it at all. If I put the same songs as the one in the smart playlist in a regular playlist it's working perfectly... There is something weird here, especially on a fresh server.
    UP, for visibility
    I dont get it: I just reported a bug and there is no acknowledgment that the devs are looking into it? At the end this forum is just like a user talk tool like reddit or a way to talk/report things to the devs?
  • mm98mm98 Posts: 452Members, Plex Pass Plex Pass
    edited April 2017
    There seams to be a problem with Sync, if you previously have had a Smart Playlist synced (ex. filter: track rating more than 1, sorted by play count). If you delete the synced item (playlist), and add it again - the logs show, that PMS think that the playlist has already been synced, and won't sync anything. PMS logs attached.
    The PlexWeb Sync list shows that the tracks are waiting to be downloaded. The iOS app (latest Plex and iOS) is waiting on the server, and doesn't download any of the tracks.
    PlexWeb (v3.4.1):
    Shows that none of the 25 tracks are downloaded.
    Plex (v4.10) on iOS:
    13 tracks won't sync to iOS.
    PMS (v1.5.5.3634) Logs:
    Apr 16, 2017 11:14:28.471 [0x7f18d7da1700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 1 new, 0 updated, 0 deleted Apr 16, 2017 11:14:28.712 [0x7f18e3623700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:14:28.978 [0x7f18e0d59700] WARN - Held transaction for too long (../Sync/SyncItemGenerator.cpp:142): 0.590000 seconds Apr 16, 2017 11:14:30.171 [0x7f18d7da1700] WARN - SLOW QUERY: It took 330.000000 ms to retrieve 23 items. Apr 16, 2017 11:14:31.108 [0x7f18d8f35700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:14:31.388 [0x7f18e3623700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:15:03.954 [0x7f18e3623700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:15:04.245 [0x7f18d8f35700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:15:56.281 [0x7f18e3623700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:15:56.565 [0x7f18e3bff700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:16:16.861 [0x7f18e3623700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:16:17.133 [0x7f18d8f35700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:16:50.506 [0x7f18e3623700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:16:50.781 [0x7f18e3bff700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:17:20.940 [0x7f18e3623700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:17:21.228 [0x7f18e3bff700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:17:22.083 [0x7f18e3bff700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:17:22.364 [0x7f18d8f35700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:17:22.905 [0x7f18d7da1700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:17:23.192 [0x7f18e3623700] INFO - Sync: downloaded 2 sync list(s) with 1 sync items(s): 0 new, 0 updated, 0 deleted Apr 16, 2017 11:18:47.893 [0x7f18d866b700] WARN - Held transaction for too long (../Sync/SyncItemGenerator.cpp:142): 0.320000 seconds
    Plex Media Server: QNAP TS-453 Pro (CPU Mark: 1864, Intel Celeron @ 1.99GHz Quad-Core, 8GB RAM, SSD, 2 x WD)
    Plex Media Clients: PlexWeb (app.plex.tv), Plex for LG, ChromeCast Ultra, iPhone 8 Plus, iPad Pro, Apple TV 4 and Sonos
    DVR Hardware: HDHomeRun EXPAND (HDHR3-4DC)
    Smart TV: LG UHD UH7500 (US) / UH750V (EU) (WebOS 3.0)
    Any update from the Plex dev team ?
    edited April 2017
    Hello? Anybody?
    edited April 2017
    Moved to a separate thread ...
    edited April 2017
  • sa2000sa2000 Posts: 30,438Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    PlexWeb (v3.4.1):
    You have disabled Debug Logging so the logs are not usable
    Please could you reproduce the problem with a new playlist but with debug logging enabled on the server.
    Please could you also include the iOS logs
    https://support.plex.tv/hc/en-us/articles/201643703-Reporting-issues-with-Plex-Media-Server
    Help given free on forums.            Fee-Based Personal Support & Help.
    _______________________________________________________________________________________
    Plex Support Information              Troubleshooting               FAQs
    Plex Media Server:   Reporting Issues        Plex Web App: Debug Log    Plex Apps: Support pages and Logs    Logs: All Logs
    Please do not send logs by Private Message unless specifically requested to
    edited May 2017
    regarding my issue, here are the logs from my server and iPhone.
    For the server I followed the steps:
    1. removed the synced smart playlist
    2. enabled logging
    3. restarted server
    4. Synced a smart playlist with the iphone
    On the iPhone:
    1. Enabled debug
    2. Synced a smart playlist
    3. !App Freeze at the end of the sync
    4. Killed the app via the app switcher
    5. Started the app
    6. Went to the smart playlist
    7. Infinite loading loop
    --> Media is working when I try to play it via Artist or Album
    Link to logs:
    https://drive.google.com/drive/folders/0Bz0E2jNUgke-VnVna0wwN0k1cDA?usp=sharing
    edited April 2017
    Fresh debug logs here
    I am aware of your sync loop issue where you have stated that syncing 96% or 97% to 100% repeats itself over and over and that is covered by evidence you provided here http://forums.plex.tv/discussion/comment/1429603/#Comment_1429603
    However in this thread you described an issue where after deletion and recreating the sync does not take place which is the issue I asked for evidence for
    @sa2000 Are you taking a look at my logs too? As it is a different problem.
    Point me to where your logs are
    Well... 5 post earlier. I'm the OP.
    I can see now - the links are showing as text and not links - hence they were not spotted
    2. enabled logging
    3. restarted server
    On the iPhone:
    1. Enabled debug
    5. Started the app
    Link to logs:
    Just to let you know I am looking into the logs
    It is repeatedly asking for 4 items over and over again
    Could you let me have step by step on how to reproduce this.
    So you view a music library by tracks
    Then filter on specific ratings
    Then create a smart playlist
    Then sync the list to iOS ?
    edited May 2017
    I just create a playlist with as filter track rating is > 3 stars. That's it!
    I have this issue on every smart playlist that I create.
  • ChandlarrChandlarr Posts: 5Members, Plex Pass Plex Pass
    Any updates from the plex team on this? I got the exact same issue
«1
