includeBandwidths?
I've just gotten around to updating to the latest PMS (1.5.4.x) and it's borked a live streaming plugin.
It throws an error saying that my createChannelObject[]
has an unexpected keyword argument of includeBandwidths
Adding it to my createChannelObject[]
with value of either 0
, 1
or False
throws a second error on iOS complaing about no direct playback for HTTP, with container MP4, codec H264, audio codec AC3. The offending code appears to be:
video_codec = "H264", audio_codec = "AAC", container = "MP4", protocols = "HTTPLiveStreaming",
(I'm using an @indirect playback method as I need to generate a URL when play is pressed)
If I remove video_codec, audio_codec and container it will play the stream, but:
- I have no idea what a value of
0
,1
orFalse
does toincludeBandwidths
as I don't know what it is - iOS complains the server is not fast enough to transcode on iOS
Prior to the updated PMS the plugin worked perfectly.
Best Answer
sander1 Channel Developer/Admin Posts: 3,844Members, Plex Pass, Plex Ninja Plex Ninja
To be honest I also don't know what
includeBandwidths
does. It doesn't seem to be a standard, at least not for channels.The reason why some clients are choking could be the mixing of
MP4
andHTTPLiveStreaming
. AlsoHTTPLiveStreaming
is not a valid protocol value. Try:video_codec = VideoCodec.H264, audio_codec = AudioCodec.AAC, container = "mpegts", protocols = "hls",
5
Answers
Instead of adding the exact "missing" parameters to my functions, I usually have added
**kwargs
(example) at the end of the function/parameters declaration. That way it'll keep working, even if anything new is (accidentally) added later in time.http://stackoverflow.com/questions/36901/what-does-double-star-and-star-do-for-python-parameters
Thanks @sander1 that helps.
It does still leave me not knowing what that argument does, and why the properties (video_codec etc.) now cause iOS to choke
includeBandwidths
MP4
is not a valid protocol value. Try:Thanks again @sander1 – will try the above.
