No audio with AC3 5.1 on Premiere+
SpunkymankerSpunkymanker Posts: 5Members, Plex Pass Plex Pass
Using plex 4.4.1 on a new Roku Premiere+.
Connected to a Pioneer VSX-43 reciever via HDMI.
Plex media server is up to date (1.5.4.3596)
All stereo streams work fine, but any videos with AC3 5.1 have no audio. If I manually set the roku to stereo only, it plays audio, but this just isn't acceptable.
I swapped out for a Roku 3 with the same verison of Plex, and everything plays fine on 'Auto' for audio, and it sounds great.
Plex for Ps4 works fine as well.
Answers
  • zacwhite15zacwhite15 Posts: 15Members, Plex Pass Plex Pass
    i just noticed this same issue on all of my devices. if i try to stream any media with AC3 5.1 it just sits there loading and then times out after a little while.
  • allogatorallogator Posts: 5Members, Plex Pass ✭✭
    Spunky, a lot of us are having this exact issue. Roku released 7.6 on 4/11 so download it and give it a try! I haven't been home yet to check it out, but do report back!
    i have confirmed this is an issue with the 1.5.4.3596-0d2d8c2be udpate, if you rollback to 1.5.3.3580-4b377d295 it resolves the issue. :)
  • activemindactivemind Posts: 22Members, Plex Pass Plex Pass
    I've been struggling with the same issue. Only Roku plex client have no audio but other cients (i.e. Web, iOS etc.) all works fine. Zac, any idea how I could get an older version of PMS and rollback? Thanks in advance.
  • DFuryDFury Posts: 245Members, Plex Pass Plex Pass
    Can you guys confirm that the files with no audio are, in fact, AC3...and not EAC3? As noted in my other thread, my Ultra wasn't abiding by my universal Roku setting to support only AC3/DTS. It was still trying to stream EAC3, which caused no audio.
  • winspiritwinspirit Posts: 10Members ✭✭
    Same Problem here, No sound with 5.1 AC3
    Updating to Roku 7.6 seems to have fixed my Plex AC3 issues--now I just have the random split second sound delays.
  • SpunkymankerSpunkymanker Posts: 5Members, Plex Pass Plex Pass
    Indeed, the update to 7.6 has fixed the issue.
  • maronismmaronism Posts: 19Members, Plex Pass Plex Pass
    I've noticed the same issue with random sound delays (just drops out momentarily), and on a few occasions I've lost sound entirely. Only a restart of the Roku returns sound.
  • danthom1704danthom1704 Posts: 7Members, Plex Pass Plex Pass
    I have Roku 7.6 and still all AC3 have no sound. 5.1 or stereo.
    I found I had to go into the Roku audio settings and set everything to stereo. It now works.
  • klrbee25klrbee25 Posts: 1Validating, Plex Pass Plex Pass
    Same issue. Roku 3 played AC3 5.1 without issue. Now the premier I just got won't play those streams.
  • D101010D101010 Posts: 1Members, Plex Pass Plex Pass
    I have same issue contacted Roku support and they said issue is with plex.
  • JuiceWSAJuiceWSA Posts: 7,076Members ✭✭✭✭✭
    edited July 2017
    ^^LOL^^
    "Hello. My Name is 'Joe Namath'.
    .....How can I help you, today?"
    (Indian accent so deep, Indians need subs)
    (the post-it note in that ash tray reads: 'Blame Plex')
    Tony
    FileBot For Easy Plex File Naming: http://www.filebot.net/
    Automated Plex Naming With Filebot: https://forums.plex.tv/discussion/191687/plex-naming-schemes-for-filebot
    Plex Friendly Handbrake Guide - DVDs/BluRays: https://forums.plex.tv/discussion/comment/1335697/#Comment_1335697
    Plex Clients: AFTVs, Androids, PMP, Rokus (running RARflix: http://mkvxstream.blogspot.com/2014/09/roku-plex-setup-guide.html ) Link May Work - May Not
  • sfnetworksfnetwork Posts: 1,402Members, Plex Pass Plex Pass
    edited July 2017
    Ok, if this is the same issue as mine, this should be taken care of ASAP, not in months....
    I own 5 Roku 3, Apple TV, NUC, etc...
    I bought a new 4K TV (Sony xbr65x900e) so even with Android TV on it, I wanted to keep using Roku, so I got a Roku Premiere Plus (because I wanted HDR with Netflix)
    I also have as receiver an Onkyo TX-NR838. It does 4K and HDCP 2.2 on one port but not HDR. Just FYI.
    And... to my big surprise, only in Plex app on the new Roku, AC3 doesn't work...
    Tried:
    -Roku - receiver - TV
    -Roku - TV - receiver (ARC)
    My TV (when connecting the second way) mentions audio not supported (which doesn't make sense...)
    I connected the Roku 3 BOTH THE EXACT SAME WAY (same inputs) as tried with Premiere Plus and NO PROBLEM with AC3 (Direct play, which is the point here).
    So this is not about a setting from TV or receiver...
    I tried just in case to change Roku display to 1080, 4K no HRD and 4K HDR 60fps.... doesn't make a difference.
    In the Roku Premiere Plus audio and HDMI settings, only setting that works is stereo (which is just because it works around the fact that AC3 coming out of Plex/Roku Premiere Plus isn't right...
    It is no acceptable to downgrade audio to stereo IMO...
    ***DTS passthrough fine, this is just about AC3 5.1... It must be the way it's output.. something must not follow standards or something...)
    I cannot confirm but I'm presuming Ultra has the same issue.
    This needs to be addressed ASAP IMO...
    Please let me know if you need me to do specific tests, provide logs, etc.. I would be happy to, but this needs to be fixed if this is a general issue (and if it's just me, well, please help lol)
    ***If really needed, I could even install/setup Emby to test in Roku Premiere Plus, if it works, NOW IT'S 100% a Plex issue...
    Let me know please how to proceed...
  • ajkidleajkidle Posts: 2Members
    This is still a problem. No audio on AC3 5.1 tracks. All other audio is fine.
    Roku Premiere+ (4630X) version 7.7.0
    Plex server version 1.9.4.4325
    Plex client 5.0 version 1
    Anyone know how to fix this, or do I need to wait for Plex to correct?
  • PheckphulPheckphul Posts: 13Members, Plex Pass Plex Pass
    Yes, I'm still having this problem, and have been for MONTHS. I'm tired of having to reboot my Roku multiple times a day!
  • superhancpetramsuperhancpetram Posts: 151Members, Plex Pass Plex Pass
    I'm also seeing this problem happen again after several months of it working. Rebooting the Roku Premiere has not yet fixed it. I noticed it after updating Plex Media Server to 1.9.6.4835, though I don't know that the two events are related.
    This seems to be fixed now after installing 1.9.6.4429
