I have a problem with a few avi's not playing
translocatedramtranslocatedram Posts: 3Members, Plex Pass Plex Pass
edited April 2017 in Xbox One
I have some avi's that will not play on my Xbox one. They play on other devices and through the web.
I just get a black screen and it times out after a while. Plex Server does not show anything under playing or conversion
The info from plex is :
Media
Video Resolution 576p
Duration 1:30:40
Bitrate 999 kbps
Width 720
Height 480
Aspect Ratio 1.66
Container AVI
Video Frame Rate NTSC
Part
Duration 1:30:40
File Carry on Cowboy (1965).avi
Size 647.63 MB
Container AVI
Indexes sd
Codec MPEG4
Bitrate 795 kbps
Bit Depth 8
Chroma Subsampling 4:2:0
Frame Rate 29.97 fps
Height 480
Level -99
Ref Frames 1
Width 720
Codec MP3
Channels Stereo
Bitrate 192 kbps
Audio Channel Layout stereo
Sampling Rate 44100 Hz
Stream Identifier 1
I think I need to add something to profile to transcode. I added this :
VideoProfile container=“avi” codec="mpeg4" audioCodec="mp3,pcm"
with a < and />
and it didn't change anything.
Can anyone help ?
Answers
  • MoussaMoussa Posts: 1,669Members, Plex Employee, Plex Pass, Plex Ninja Plex Employee
    Could you post your media XML, as it's more detailed. You can find instructions here under the XML Information section. Grab the contents of that page.
  • translocatedramtranslocatedram Posts: 3Members, Plex Pass Plex Pass
    Apologies for the Carry on example.
    and thanks again
    I've posted the XML
    Thanks for your help
