QNAP plex won't load port 32400
englemtenglemt Validating, Plex Pass Posts: 2 Plex Pass
I upgraded my QNAP and the plex app today and now I can't access it. All of my other apps look good.
I tried uninstalling and reinstalling (I have 2000 movies so uninstall took forever).
Upon reinstall, I still can't hit http/s on port 32400.
Any logs I can check for obvious errors?
TS-870 Pro
CPU Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz
Firmware version 4.3.3.0154 Build 20170413
PlexMediaServer_1.6.0.3698-7fe404e94_x86.qpkg is the one I installed today.
Best Answer
  • englemtenglemt Validating, Plex Pass Posts: 2 Plex Pass
    Accepted Answer
    I answered my own question in case anyone cares.. The old version of QNAP (4.2.x) required the x86 version of plex, the new release (4.3.x) needs the 64bit version.
Answers
    Accepted Answer
  • seb2015@hotmail.comseb2015@hotmail.com Members, Plex Pass Posts: 6 Plex Pass
    Have the same issue and Im trying that right now , will let you know . Thanks
    Yep it worked :) thanks
    Unfortunately I uninstalled my PMS before seeing your messages so I lost all my metadata and have to re-index everything. Now running v1.6
  • 1wadafl@gmx.at1wadafl@gmx.at Members Posts: 1
    I had the same problem. Now it works fine. Thanks for the hint!
