Hey folks, there is a new Podcast category for forums https://forums.plex.tv/categories/podcasts
How do I add movies to Plex using synology NAS?
ultrapuremetal@sbcglobal.netultrapuremetal@sbcglobal.net Posts: 5Members, Plex Pass Plex Pass
Can I please get step by step instructions for adding a movie using Synology NAS?
Thank you.
Best Answer
Answers
  • trumpy81trumpy81 Posts: 11,041Members, Plex Pass, Plex Ninja Plex Ninja
    edited May 2017
    First step is to make sure your Movie file/s are named correctly. Movies should follow this template:
    Movie Title (Year).ext where Movie Title is the name of the Movie, (year) is the year of release (default is the US release date) and .ext is the file extension such as .mp4, .mkv etc.
    EG: Alice Through The Looking Glass (2016).mp4
    For more information regarding File Naming in Plex, see the link in my signature.
    I also recommend that you use FileBot to automatically rename your files for you.
    FileBot for Synology:
    https://www.filebot.net/forums/viewtopic.php?f=3&t=1802
    Plex naming schemes for FileBot:
    https://forums.plex.tv/discussion/191687/plex-naming-schemes-for-filebot/p1
    FileBot Introductory Videos:
    http://www.filebot.net/getting-started/
    FileBot may be installed on a PC/Mac/Linux machine also.
    Next step read Q3 - Q6 on the Synology FAQ's page, link in my signature.
    When that is done, place your Movie file/s into the Movie folder and then create your Movie library in Plex.
    Open the Plex home page and then click on the + beside the name LIBRARIES. Select the appropriate type for your library and name it (or you can use the default name) and click on next. Then click on 'browse' and navigate to the location of your Movies folder on the NAS and select it, click on add. Next, click on 'Add Library'.
    Note, your shared folders will be on volume1 unless you create them elsewhere.
    Assuming you have correctly named files in your Movies folder, Plex will proceed to scan the contents of that folder and add your Movies to the Movies library. Plex will also analyse your files (for file parameters etc.) and download metadata and posters and then include that information in your library.
    Depending on the number of files you add, Plex may take a short time or a long, long time to complete that task.
    When you wish to add files to your Movies library, simply drop them into the Movies folder and Plex will automatically scan the folder after a minute or two and then proceed to add the new files to your Movies library.
    The same applies to TV Shows, but note that the file naming used for TV Shows is quite different to Movies, so make sure you visit the File Naming in Plex link in my signature.
    Regards,
    Andy M.
    My Equipment: Synology DS1813+ | Panasonic TH-L42ET60A & TH-55DX600U | Windows 10 Professional 64Bit PC's | Raspberry Pi 2's & Odroid C2 with OpenPHT
    Device Profiles | File Naming in Plex | NAS - Plex Compatibility Guide | What CPU does my NAS have | Synology FAQ's page | Tips & Tricks
  • ultrapuremetal@sbcglobal.netultrapuremetal@sbcglobal.net Posts: 5Members, Plex Pass Plex Pass
    Is it necessary to use parenthesis around the year?
  • kegobeer-plexkegobeer-plex Posts: 5,866Members, Plex Pass, Plex Ninja Plex Ninja
    Yes. Make sure to follow the Plex naming conventions exactly, otherwise you will have odd issues pop up. The link to the naming convention is in trumpy's signature.
    Where are my log files?
    How do I properly name my media files?
    Plex Dance
    NVIDIA SHIELD SMB/NAS Sharing How-To - / - NVIDIA SHIELD Support Documents
    Plex Server: Running on ThinkServer TS140 w/Server 2012 R2 Essentials
    Primary Plex Player: Shield TV, always the latest beta build, always the latest firmware revision
    Accepted Answer
    Thank you, I appreciate your advise.
  • LeadfingersLeadfingers Posts: 3Members ✭✭
    I just got a Synology DS1517+ and it's running Plex Server 1.12. I can't seem to load any movie files into it. We're running a Plex server on a local PC at the moment, so our content is formatted properly. Just can't seem to get it to see the files.
    Then I suggest you read and follow the replies you received in the other thread.
    https://forums.plex.tv/discussion/comment/1678476#Comment_1678476
    Regards,
    Andy M.
    Figured it out yesterday. I forgot to update this thread. It was permissions on the NAS. The Plex account didn't have permissions to target folder, so naturally, it couldn't load a library from there.
    In future, instead of hijacking year old threads why not create your own?
    That makes it easier to get the help you need and it makes it easier to find the answers you are looking for and don't forget about search, it can find answers already given for issues such as this.
    Regards,
    Andy M.
  • cul8rmom1cul8rmom1 Posts: 117Members, Plex Pass Plex Pass
    Darn. I was too late :D.
    My configuration
    Media Server Primary: Custom built ESX 5.5 server with DSM 3612sx 12x 4TB drives
    Media Server Secondary: Dell R610 running ESX 6.0 with DSM VM installed for plex backup/dev/testing.
    Media Storage Primary: DS1813+ 4GB RAM 8x 4TB HItachi NAS drives
    Media Storage Secondary/download coordinator: Synology DS1815+ 16GB RAM, w/ 8x 4TB mixed drives,
    Media Clients: Laptops, iPad, Android tablets, iPhone 5S, iPhone 6+, Appletv3 (Plexconnect hack) Appletv4, nvidia sheild portable, ChromeCast, Roku.
    Network: 3x Dell Powerconnect 5424s. Asus router running merlin firmware.
    Surveillance Station: 14 cameras.
    And on and on and on......
