No AC3/DTS sound after upgrading to PMP 1.3.0 (RPi embedded)
mindridermindrider Posts: 3Members, Plex Pass Plex Pass
Hello,
After the latest PMP upgrade my sound is broken, which is odd as according to the release notes there was only bug fixes.
In more detail, my setup uses RPi's hdmi as output and a hdmi video/audio splitter outputs the audio to optical.
My bluray player/home theater amp., which is where the optical cable is connected to, used to identify the audio as ac3 5.1 or DTS or whatever, according to what stream is present in any given media.
After the upgrade this doesn't happen anymore and it seems that the stream comes out as PCM 2.0, just like when you are in the player menus. And ofc you can hear that something is completely wrong.
I tried all possible audio settings combinations without any luck.
My setup works as expected when I use RasPlex.
So, my questions are:
  1. Is this something known ? and if yes, when is going to get fixed?
  2. Where can I download the previous version(s) of PMP?
  3. Can someone say what is the cause of this issue?
Thanks and best regards,
George
Best Answer
«13
Answers
  • RICH|FLIXRICH|FLIX Posts: 126Members, Plex Pass Plex Pass
    edited May 2017
    I'm seeing this problem as well.
    The pi no longer outputs any audio when hdmi is selected as a device, i now need to select one of the other audio devices, which will play sound (still via hdmi funnily enough) but downmixed.
    PLEX Server on unRAID | PLEX Server on WD PR4100
    Mac mini | Nvidia Shield | iOS | tvOS | Xbox One | RaspberryPi Embedded | Roku | Chromecast | Windows 10
  • coneybeareconeybeare Posts: 83Members, Plex Pass Plex Pass
    Just wanted to add a plus one here for seeing this bug. I have been going nuts trying to figure out what is going on with audio today. Data points/observations
    1. PMP 1.3.0 running through HDMI
    2. Navigation audio sounds work, any file's audio does not.
    3. Media files have audio which plays in plex.tv browser
    4. Speakers/receiver all work with other sources, and tone tests.
    5. This seems to be a regression in 1.3.0 only.
  • LongChairLongChair Plex Dev Team Posts: 669Members, Plex Pass, Plex Ninja Plex Ninja
    Could you guys post any logfile where we could see what's happenning ?
    Plex Dev Team
    Sure, here's the log from the pi after I tried to play a movie with HDMI selected as the output device.
    This would have output multi channel audio before, but after 1.3.0, i get no sound whatsoever.
    Thank you for following up on this.
    Rich
  • mindridermindrider Posts: 3Members, Plex Pass Plex Pass
    Thank you guys for the feedback to my question and especially for your actions (Github post, logs) :smiley:
    @LongChair : Please let me know if you need another set of logs
    George
    Here are two recent logs. I just played a file and no audio was sent through HDMI. The navigation click sound still does play through HDMI though.
    Another thing I've noticed, is that the navigation button click sound now works (there was no noise when I would navigate the menu before).
    I don't know if that's got anything to do with the passthrough problem, but I thought it was worth mentioning as it's also sound related.
  • gmfvisorgmfvisor Posts: 4Members, Plex Pass Plex Pass
    edited May 2017
    I had so many troubles using that audio setup but here is what worked for me (and still puzzles me):
    My hardware setup:
    RPi3 /w PMP1.3 - hdmi to - LGTV - optical out to - Marantz AVR.
    My audio/software setup:
    PMP Audio is set to hdmi: No sound.
    PMP Audio is set to optical-out: Perfect sound.
    I am not sure if I just do not get the audio config or if that is just the way it should be. But my intuition still tells me I should use hdmi out and it should work that way.
    Another data point, this is also presenting on YouTube and Plex videos played from the queue. Pretty much any audio that is not a user interface click will not come through. I don't have an optical out to try or an internal speaker, but the HDMI input works well when playing through VLC or Plex Web
  • huntandersonhuntanderson Posts: 4Members ✭✭
    I'm having the same problem. RPi3 (PMP 1.3.0) -> HDMI -> Denon receiver. Since the update, all DD/DTS (5.1 or 7.1) over HDMI is being mixed down to 2.0. No combination of audio preference changes restores surround sound.
    Is there any update on this bug? Plex Media Player is completely unusable in my setup until fixed.
  • MrWorfMrWorf Posts: 104Members, Plex Pass Plex Pass
    Same here, no matter what I choose in settings, I get 2.0 sound. Using RPi3 with 1.3.0 connected to Yamaha receiver via HDMI. Using tvservice & edidparser I could see that the RPi is properly detecting support for multichannel, so this seems to be an issue with pmp not sending the correct sound.
    I have 3 alsa devices to choose from in the settings->audio->devices where the last one is identified as HDMI. If I select that one, I get no sound at all, the other two works fine but 2.0 only.
    I've tried disabling the HDMI settings I had in /flash/config.txt, but it still didn't bring back >2.0 channels.
    @LongChair I've added logs and other stuff to the git issue. Would be awesome if this got some love in the near future since I've converted my entire BD and DVD library to MKV to use Plex and now there is no surround sound :( and I'm sure I'm not alone with this issue :)
    Gets more interesting, tried the speaker-test app with the -c 6 option (white noise will be played on each channel in a 5.1 configuration) and only one channel actually produced any sound (front left). Which matches what amixer says (mono) but it makes me wonder if things are even worse, that it's not even 2.0 sound, it's actually 1.0 (!!!)
    edited May 2017
    I tried the latest build that i have, and i seem to be having issues with selecting the iec958 device from the audio devices list.
    Although it seems that using Auto Select devicewould work to get 5.1 on my AVR here.
    Could anyone confirm this ?
    @RICH|FLIX : that is typically what i see in your logs
    Plex Dev Team
    When looking at your logfile, it seems the file you're playing is stereo :
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |+ segment information...
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: | + muxing app: libx264 + libebml + libmatroska + libfastrar
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: | + writing app: FastLE v3.0.0 - AVS
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: | + timecode scale: 1000000
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: | + duration: 1701.533s
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: | + segment uid 8a 98 33 8c d7 c0 92 dc bc 53 0f 4e f3 ef 00 be
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |+ segment tracks...
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: | + a track...
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Track number: 1
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Track type: Video
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Video track
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |   + Display width: 720
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |   + Display height: 404
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |   + Pixel width: 720
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |   + Pixel height: 404
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Codec ID: V_MPEG4/ISO/AVC
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + CodecPrivate, length 45
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Language: und
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Default duration: 41.708ms ( = 23.976 fps)
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Track number: 2
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Track type: Audio
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Audio track
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |   + Sampling frequency: 48000.000000
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |   + Channels: 2
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Codec ID: A_AAC
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + CodecPrivate, length 2
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |  + Default duration: 21.333ms ( = 46.875 fps)
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: |+ found cluster
    2017-05-08 09:56:01 [ DEBUG ] PlayerComponent.cpp @ 505 - mkv: Deferring reading cues.
    Plex Dev Team
    edited May 2017
    @LongChair Sure, but the problem persists on any file. Navigation sounds work through HDMI. Plex Web works through HDMI. Plex Media Player does not play through HDMI at all, on any file.
    While you investigate, is there anywhere I can redownload PMP 1.2.5 to work around the regression?
  • markus101markus101 Posts: 183Members, Plex Employee, Plex Pass, Plex Ninja Plex Employee
    @coneybeare you can grab 1.2.5 from https://www.plex.tv/downloads/ We've pulled 1.3.0 for the time being while we investigate this and another issue.
«13
