How do I filter by header compression, ref frames or bit depth?
jdgrensjdgrens Posts: 18Members, Plex Pass Plex Pass
Hi All,
Roku stick has an issue with files that contain header compression (causes jittery video) or high ref frames/bit depth (will transcode). I know that i can view the properties file by file in plex, but is there a way to export this data into an excel sheet, or filter within the app?
Thank you!
Best Answer
  • jmckeejmckee Posts: 5,003Members, Plex Pass, Plex Ninja Plex Ninja
    edited May 2017 Accepted Answer
    For similar situations I have used this tool (Previously known as Plex2CSV):
    https://github.com/ukdtom/ExportTools.bundle
    The way I used it was to export into an excel sheet and then used excel to filter based on the column I needed at the time
Answers
  • jdgrensjdgrens Posts: 18Members, Plex Pass Plex Pass
    awesome! thank you! there doesn't seem to be a way to check for header compression but works for bit depth and ref frames.
    thanks again!
