Samsung S8 will only stream Original or 480p using mobile streaming
sjardinasjardina Members, Plex Pass Posts: 1 Plex Pass
I have a new Samsung S8. As long as I am connected to WiFi even remotely I can change the bitrates for video within the application with no problem. When I turn off WiFi and use mobile the Plex application will only play videos in Original or 480p. If I try to manually select a bitrate the application crashes.
Comments
  • chamber82chamber82 Members, Plex Pass Posts: 2 Plex Pass
    Having the same issue. Im not on an S8, im using a Nexus 6P on the latest version.
    See here,
    If I set the android app defaults to 3Mbps 720p when on mobile data it will trancode a file down.
    The file is 3Mbps 720p so should be original quality but Plex is transcoding it to 476x268.
    If I set the options to original and then try and Transcode it down, the app crashes.
