Plex does not start after installation on Ubuntu 16.04
SaschaK SaschaK  Posts: 18Members ✭✭
First: Sorry for my bad english.
I wanted to install the Plex media server on a fresh Ubuntu 16.04. It is the server version without GUI.
What have I done:
wget https://downloads.plex.tv/plex-media-server/1.5.6.3790-4613ce077/plexmediaserver_1.5.6.3790-4613ce077_amd64.deb
sudo dpkg -i plexmediaserver_1.5.6.3790-4613ce077_amd64.deb
sudo reboot
sudo mkdir /var/lib/plexmediaserver
sudo chown -R plex:plex /var/lib/plexmediaserver
sudo systemctl enable plexmediaserver.service
sudo systemctl start plexmediaserver.service
Then I had to realize that Plex does not start, which I found as followed:
root@plex:/# sudo netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      7918/named
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      8064/sshd
tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      7918/named
tcp6       0      0 ::1:53                  :::*                    LISTEN      7918/named
tcp6       0      0 :::22                   :::*                    LISTEN      8064/sshd
tcp6       0      0 ::1:953                 :::*                    LISTEN      7918/named
udp        0      0 127.0.0.1:53            0.0.0.0:*                           7918/named
udp6       0      0 ::1:53                  :::*                                7918/named
root@plex:/# sudo systemctl status plexmediaserver
● plexmediaserver.service - Plex Media Server for Linux
   Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: signal) since Thu 2017-05-18 09:57:47 CEST; 4s ago
  Process: 23705 ExecStart=/bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver /usr/lib/plexmediaserver/Plex\ Media\ Server (code=killed, signal=ABRT)
  Process: 23701 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_
 Main PID: 23705 (code=killed, signal=ABRT)
May 18 09:57:47 plex systemd[1]: plexmediaserver.service: Unit entered failed state.
May 18 09:57:47 plex systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Best Answer
  • SaschaK SaschaK  Posts: 18Members ✭✭
    Accepted Answer
    Problem solved!
    At the server I chose the language "German", so he apparently did not clear. Reinstalling the server with English has helped.
Answers
    Accepted Answer
    Problem solved!
