remote access fails 3 seconds after connection
dgrungedgrunge Posts: 8Members, Plex Pass Plex Pass
My Remote access feature will connect for about three seconds then it disconnects:
I am running windows 10 and Plex is up to date.
It's not double NAT
My modem / router is a Netgear D6200
UPnP is enabled
The router firewall is off
windows firewall is off
It still fails when i remove my virus protection software
I've created a static local IP for my server.
I've manually specified a port for Plex through the router's software and have also tried using a different external port for external and specified a path to Plex's internal 32400 port all for the same result.
any help would be greatly appreciated,
Thanks, Damien.
Answers
  • jmeehan11jmeehan11 Posts: 83Members, Plex Pass Plex Pass
    latest versions seem to have an issue with UPnP.
    Try to check Manually Specify a port, leave it on 32400.
    Then do port forwarding on your router.
    Worked for me.
  • dgrungedgrunge Posts: 8Members, Plex Pass Plex Pass
    Worked for me.
    Thanks,
    have tried that and no luck - same result
    DG
  • astrofisherastrofisher Plex Dwarf Star Posts: 5,514Members, Plex Pass Plex Pass
    Have you tried the port forward with UPnP disabled on the router?
    Jim
    "I never had any friends later on like the ones I had when I was twelve. Jesus, does anyone?"
    Rule #32 "Enjoy the little things"
