[Bug] Create Smart Playlist from 'traditional' filters not working
beckfieldbeckfield Posts: 3,838Members, Plex Pass Plex Pass
Before the Custom Filter feature was added, I could do the following:
  1. In Music library, select 'Genre' > 'Celtic' from Filter menu.
  2. Click 'Add to playlist,' name it, and save.
A smart playlist was created with all Celtic tracks. Adding 'Celtic' tag to additional tracks automatically added them to the playlist.
Now, this no longer works. If I follow the steps above, the Smart Playlist is created, but it is empty. If I manually select all the albums after Step 1, then click 'Add to playlist,' it wants to create a standard playlist, not a smart one.
Comments
  • OttoKernerOttoKerner Posts: 30,245Members, Plex Pass, Plex Ninja Plex Ninja
    confirmed and filed as a bug
    Got help? Help others too - by reporting back with your results!
    Have you checked the Documentation before posting a question in the forums?
    Use the SEARCH function before starting a new thread!
    No PMs unless requested, please! Do not use 'verbose' logging
