Running out of storage. Can I use two portable hard drives and assign the same drive letter?
UnicornWasherUnicornWasher Posts: 65Members, Plex Pass Plex Pass
Greetings! I have a seagate 8TB portable hard drive. With tons of tv, some music, and 1300 movies, I am running out of storage. Can I buy a second 8tb hard drive and just assign the same letter? Or, if I choose to name it another drive letter, can Plex recognize two different hard drives? Thanks in advance. :)
Primary PMS: Nividia Shield Pro
Media Storage: Plex: (4) Seagate Expansion 8TB Desktop External Hard Drive; 3.0 USB
Desktop Clients: Windows web app (wired), Chromecast Ultra (wired), Chromecast 2nd gen (wired), Fire TV Ultra (wireless)
Mobile Clients: Moto X, 2nd gen
Remote Users: 3
Best Answers
  • ChuckPAChuckPA Posts: 22,196Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    Accepted Answer
    I am saying:
    1. After you add the next drive (E:\)
    2. Create a Movies directory on it (or whatever you need)
    3. Edit the appropriate Library section and tell PMS to look in E:\Movies too for movies
    4. You can move stuff OFF D:\Movies and over to E:\Movies
    PMS won't care. Just remember to Update Libraries after you've done everything and it hasn't been following along (Automatically update my library as changes are detected in Settings - Server - Library)
    Please DISABLE Verbose logging until requested
    Please search before posting
    Primary support: Linux, Synology, and QNAP
    Please remember to report back. This benefits others.
    Useful links
     Installation and Basic Setup |  Media Preparation (How to name your media files)  |  Linux Permissions
     Handling TV Specials | Handling Movie extras  |  Nas Compatibility
     Reporting Plex Server issues | Plex Media Server FAQ | Linux Tips
    Other useful guides: Local Subtitles | The Plex "dance" | Synology FAQ | PMS Release Announcements
    Hosts: Fedora, QNAP, Synology, most Linux distros in VM
    No technical support via PM unless offered
    Please remember to mark the appropriate answer(s) which solved your issue.
  • spikemixturespikemixture Posts: 1,563Members, Plex Pass Plex Pass
    edited July 2017 Accepted Answer
    You just plug in the NEW drive give it a letter then goto Plex as you did originally and add the new drive.
    So now in Plex you will have it pointing to e.g. d:\movies AND E:\movies ?
    does that make sense?
    Plex related : NAS Qnap TVS-1282, (Plex server & main storage) Synology 1817+ (backup Plex server & backup storage), 2x NUC (Skull i7 , i5), Drobo 5N and 2 Nvidia Shield Pros (backup Plex servers)(2017 and 2015)
    Client hardware used or using - Shield 2015 pro and 2017 pro, ATV4, Xbox 360 and one, Fire stick and TV, windows PMP, Raspberry PI, Roku Stick, 3 and 4 plus several Android Phones and Tablets.
    I give MY opinion from MY experience!
    So much importance is put on the processing power of your PMS box.
    I say equal or more should be put on correctly formatting and optimizing your media !
Answers
    Plex doesn't care where the media is stored. When you create the library, you tell it where to look. If you add another storage location, add that to a Library section, move media from one drive to another, PMS won't care.
    The full procedure is here. https://support.plex.tv/hc/en-us/articles/201154537-Move-Media-Content-to-a-New-Location
    Useful links
  • UnicornWasherUnicornWasher Posts: 65Members, Plex Pass Plex Pass
    Goodness, Chuck. Thank you for such a fast reply. :) :) I probably did not explain my issue correctly. ( I do understand the instructions you gave and I have followed them when I previously upgraded my portable hard drive to increase its size.) My issue is that I want to have TWO different hard drives at the same time... each at 8TB. I have nearly filled up one 8TB hard drive and I want to keep that media on my first hard drive and ADD ANOTHER 8TB hard drive.... so that I have a total of 16TB, not 8TB. I don't want to replace one 8TB hard drive with another 8TB hard drive.
    I would like to use TWO different 8TB hard drives for a total of 16TB for my server. (The reason for two is that I already have one 8TB hard drive and to add another, that would costs under $200. To buy a single hard drive with 16TB would set me back a whopping $500.)
    So, can I have TWO hard drives that share a drive letter? I know it is physically possible, but will PLEX handle that? If I have TWO hard drives each with a different drive letter, will Plex even allow me to do that?
    Is there a solution other than having to spend $500??
    Thanks again. ;)
    Remote Users: 3
    edited July 2017
    Ah, then I misunderstood your question. You want to know if you can upgrade the internal storage HDs .
    As I understand Windows. You install the new HD, format it and assign a drive letter.
    As example,
    D:\Movies   (the original)
    E:\Movies   (the newly created one with a `Movies` directory you just created)
    All you need do is Edit your Movies Library section and Add folders. When you Browse for Folders, add E:\Movies to the list. Save the changes
    It's that painless. PMS will do the rest of the scanning automatically. To PMS, it's a list of media sources. :)
    Now, you can move things around from D -> E.
    Is this what you want to do?
    Useful links
    edited July 2017
    LOL, Chuck. It is me, not you. I "think" understand your answer though... so I am getting closer at being able to articulate myself ;).
    1) I want to keep all media I have on D:/. I do not want add anything more to D:/ (because I have run out of room! ;))
    2) I then want to add ANOTHER hard drive so that I have more room to add more media.
    Are you saying I can keep all current my media on D:/, then add a folder to my library on D:/ and assign E:/ to that folder?
    So, library is assigned to D:/ and then within that library is a new folder that I can assign to my new E:/ drive??
    Thank you for your patience. :)
    Moderator Edit: "Code" paragraph formatting fixes many evils >:)
    Remote Users: 3
    drat! All those frowny faces are D drive.
    Remote Users: 3
    Accepted Answer
    I am saying:
    Useful links
    Thank you, Chuck. I appreciate all your help. I think I understand what you are saying. I will play around with that a bit later to see if it will work for my needs. :)
    Remote Users: 3
    YESSSS!!! Thank you, Chuck and spikemixture. I tested out what you both wrote and it works. Thank you for saving me $$$. :)
    Remote Users: 3
  • tshaftoe83tshaftoe83 Posts: 1Members
    Do you need the drives to be cloud drives? I have one Seagate cloud drive which runs plex amazingly well. I'm looking at getting a second and splitting my library. Just wondering if it matters what kind of second network drive I get. Thanks
    In short no it does not matter.
