Using another agent in a custom agent
psycikpsycik Posts: 401Members, Plex Pass Plex Pass
Can i call another agent from inside another, so a TV Series based agent, could i make a call to thetvtb agent, or do I have to implement calls to the tvdb api directly?
Plex for IOS, PlexConnect, Roku3 and NextPVR Channel
Plex PMS on AMD A10 for movies and TV, and Plex PMS on AMD A8 with NextPVR custom scanner and Agent
Answers
  • ZeroQIZeroQI Posts: 1,248Members ✭✭✭
    @psycik some agent can call fonctions in another agent to convert the unique id for example.
    i saw it in some agent source code but cannot remember which...
    Also you can have secondary agents so you do not have to manage fallback like that...
    Depends what you want but in short yes
    Absolute Series Scanner (ASS): Seasons+Absolute mode series scanner managing subdirectories and AniDB type specials,with a logging off all files (skipped on top of root folder, then sorted one line per file with regex used and info, all series sorted alphabetically) and one with the filelist to reproduce the library on my end with dummy files. It also add all files and recognise specials pretty accurately.
    http AniDB Metadata Agent (HAMA): Some good info there, will have to re-write it at some point... Data folders are kinda mandatory... Huge libraries can fetch 10gb in space. If you have no poster but other metadata is showing, create "Plug-in Support/Data/com.plexapp.agents.hama/DataItems" agent folders as indicated in the readme on GitHub
    Impressed by the agent recognition rate? Consider donating few euros through Paypal: Absolute Series Scanner + HTTP AniDB Metadata Agent. (Donators: xnaas, Sven-7, Niegen, Vorador, Fratal, T. Mayville,  A. Estremera, KJKingJ. Thanks guys)
  • psycikpsycik Posts: 401Members, Plex Pass Plex Pass
    I saw some of the agents calling themoviedb agent. But I couldn't adapt for thetvdb.
    I want to get episode information myself, but series and show details/images from thetvdb - without necessarily having to write calls to thetvdb api directly.
