Plex "stuck" with one audio language
antoxa256antoxa256 Posts: 8Members ✭✭
Hello community!
Couple weeks ago I've faced a strange problem with my Plex setup: no matter what audio track is selected - every video plays with Russian track, and when you change the track in the Plex player - just nothing is changing.
It only changes if I enable any subtitle but in this case video starts buffering and than crashes.
I have a latest Plex server installed on MacOS and Plex player on Samsung smart tv (v 3.1.0).
I suspect it has something to do with the update of the tv app on 06/30/2017...
Answers
  • SE56SE56 Posts: 2,265Members, Plex Pass Plex Pass
    @antoxa256 said:
    Hello community!
    I believe you need to separate your preferred Languages and take careful not of settings in each Library for Languages .
    TV:(1). LG 65UB950T UHD Smart TV WebOS 1.4, (2). Hisense 50K3300UW.Receiver Onkyo TX-NR646 Network Receiver, ARC configured. Server: iMac Late 2015, 32Gb Ram, 3.2GHz Intel i5 Skylake processors.Storage: 3 WD External USB3 HDD. Devices: 2 iPad Air 2 connected with AC Wifi Dual Band. Network: Gigabite Ethernet hardwired , 5 outlets with Cat 6 and 2 Ethernet switches, Full Duplex, AVB mode enabled Remotes: Onkyo ios app, Plex ios, LG Magic remote.Speakers: Bowers and Wilkins Floor Standing Fronts and Mordaunt-Short Genie, Centre, 200W Powered Sub & 4 Satellite Surrounds. Configured for 7.1 Channels.
  • antoxa256antoxa256 Posts: 8Members ✭✭
    I'm not quite understand what you mean..
    My preferred sound language is set to English and it has never been changed.
    I think the problem is in the TV app - it requests incorrect streams form server, but reinstallation hasn't helped.
    as per attachment.
    @Gdr56 said:
    as per attachment.
    Now I've got it, but as I said - the English language is set as default everywhere.
    Even in Plex player is says that "English" is selected but it plays Russian stream.
    The following may explain
    As I've said - English is set as default everywhere.
    I repeat: this is not the case.
    Including the player/TV
    Folks, any ideas? Very strange issue..
  • SifjarSifjar Posts: 2Members, Plex Pass Plex Pass
