issue with TV-Shows
NewN00bNewN00b Posts: 4Members, Plex Pass Plex Pass
Hi all
I've an issue with a tvshow. In fact I've created an own tv show and added some metadata. The name and the episode will be recognised by Plex but the episode description is blank, the "aired" date and the age rating as well. For the tagging I use iFlicks (v) and Meta X. Further, the tags are available in a XML or NFO file.
Answers
  • OttoKernerOttoKerner Posts: 29,567Members, Plex Pass, Plex Ninja Plex Ninja
    Plex only reads episode names from mp4 / m4v files.
    If you have Kodi-compatible .nfo files, install the .nfo importer agents. then perform a 'Fix Match' with the show.
    Select 'Auto-Match', - 'XBMC nfo tv importer'
    Got help? Help others too - by reporting back with your results!
    Have you checked the Documentation before posting a question in the forums?
    Use the SEARCH function before starting a new thread!
    No PMs unless requested, please! Do not use 'verbose' logging
  • NewN00bNewN00b Posts: 4Members, Plex Pass Plex Pass
    edited July 2017
    Hi - will try it today However, the affected files are mp4 - However, Thanks
    Make sure 'Local Media Assets' are activated under
    Settings - Server - Agents - Shows - Personal Media
