Control RasPlex over network?
NeodudeNeodude Posts: 31Members, Plex Pass Plex Pass
Hey folks,
I have a number of RasPlex's setup around the house and 2 in remote locations. The 2 in remote locations are used by my Father and my Monster-in-Law. They are not the most tech-savvy people on the planet and struggle with the basics of RasPlex especially as they only use it occasionally.
With this in mind I was wondering if there was a way to control these boxes remotely? I have setup Dynamic DNS and can access them via SSH but was hoping there would be a way to control them via the GUI remotely, something like VNC possibly?
Plex Server: Home Server "Gandalf": unRAID Pro 6 | Case: Lian-Li PC-D600WB | MB: ASUS Z9PE-D8 WS | CPU: Dual Xeon E5-2670 | RAM: 64GB Crucial PC-1600 ECC | Cache: 2 x Samsung 850 EVO 1TB | Array: 4 x 4TB WD Red, 4 x 3TB WD Red | Gaming VM: Win10 & MSI GTX1070
Players: 6x RasPlex on RPi3.
Best Answer
Answers
  • NeodudeNeodude Posts: 31Members, Plex Pass Plex Pass
    That will certainly do the trick for now. VNC server would be nice though :)
  • videotecaCNSUvideotecaCNSU Posts: 317Validating, Plex Pass Plex Pass
    I dont understand what you are trying to do, a VNC server is really not needed
    if you want a GUI you can use the original plex app and use the cast feature so it works as a remote, plus I remember that there were some other apps that worked as a remote and a web app that I think that used xbmc-send to send commands to the player
  • oviziiovizii Posts: 30Members ✭✭
    But to be able to use the plex app on your phone you'd have to be on the same network as rasplex, right? So he could VPN into his father#s network then pley/cast from his phone using the plex app?
    Yes, a vpn should do the trick or you can vnc to a pc in that network from where you run the client itself. Even from the web player you can control it
