EAE Error: Cannot Transcode TrueHD audio
anhtuan99anhtuan99 Members Posts: 38 ✭✭
edited August 6 in Linux
I'm running Plex 1.8.0 and cannot get TrueHD audio transcoding to work. Had this issue on 1.7.5 as well as earlier versions. I've attached my logs. Please help diagnosis.
Answers
  • sa2000sa2000 Members, Plex Pass, Plex Ninja, Plex Team Member Posts: 28,091 Plex Team Member
    could you check that there is enough space in /tmp
    Easy Audio Encoder was using this path
    /tmp/pms-3088c15b-9476-480a-b295-5c4c4e6ba9fc/EasyAudioEncoder
    where is the error text displayed?
    Help given free on forums.            Fee-Based Personal Support & Help.
    _______________________________________________________________________________________
    Plex Support Information              Troubleshooting               FAQs
    Plex Media Server:   Reporting Issues        Plex Web App: Debug Log    Plex Apps: Support pages and Logs    Logs: All Logs
    For list of 3rd party programs and malware / adware crashing Plex Media Server and mswsock.dll on windows, see Repeated crashing of Plex Media Server on Windows
  • anhtuan99anhtuan99 Members Posts: 38 ✭✭
    edited August 2
    There's plenty of space in /tmp.
    Error on my Android TV Plex App: "Playback has stopped because the connection to the Plex Media Server has been lost. Please ensure the server is available and retry."
    I know the error is misleading because I get this error whenever the transcoder crash or when there's permission issue.
    Some questions that may help understand the problem
    • Does the file play ok on other plex apps - other than the android TV app
    • Do all TrueHD / Dolby media files fail
    • When you start playing such a file, a process gets run and remains running. The executable run was this
      '/opt/plex-config/plex-hd/Plex Media Server/Codecs/EasyAudioEncoder-141-linux-ubuntu-x86_64/EasyAudioEncoder/EasyAudioEncoder'
      Can you tell if it remains running? Does it start running?
    • What do you have specified as the Transcoder Temp Directory? (Settings / Server / Transcoder / Show Advaned)
    Do you know if the iNotify functionality is working in your environment ? It is relied on for EasyAudioEncoder -
    I notice that you do not have it in use for library updates
    edited August 2
    Ionotify works in my environment because I use the "Update my library automatically" settings and it works.
    This is error is particular to Android TV Plex App because I know it's using EAE to do TrueHD -> AC3/EAC3 conversion. Playing from Plex Web app works fine because TrueHD -> AAC conversion isn't an issue because I believe it doesn't use EAE. I use /dev/shm as the Transcoder Temp directory and it still doesn't work when I change it to /tmp.
    Will have to test it again later when I get home on the Android TV app to see if EasyAudioEncoder starts running at all.
    And next of evidence please also include android app log
    Can you show me how to grab the log from the android app?
    And FYI, I've increased the fs.inotify.max_user_watches & fs.file-max in /etc/sysctl.conf to 524288. This fixed an issue with EAE previously but it stopped working again a few updates again.
    It is through the ip of the tv and port 32500
    See https://support.plex.tv/hc/en-us/articles/201573117-Android-Android-TV-and-Fire-TV-Logs
    There are no references to iNotify in the log you provided
    In fact it says auto library update is off
    Aug 01, 2017 00:37:59.754 [0x7f83797fd700] DEBUG - Starting scheduled updates, every 3600 seconds
    Aug 01, 2017 00:37:59.754 [0x7f83797fd700] INFO - LibraryUpdateManager path watching is disabled
    I did turn it off when I was trying to reproduce this error because it would spam the log with thousands of "Watching..." messages.
    This issue seem to be related to a combination of the Plex Media Server and the Plex App on the Android TV. On the Android TV app, I get the error if I try to play the video at Original quality I get the error. However, if I reduce the quality to 1080p 8mbps the video plays fine. I've attached both the server log and the Plex App log here.
    Thank you will be looking at the evidence. Does look like the Andoid TV App did not like the high rates.
    It does not help the investigation when the clock on TV app is 2 hours 23 minutes and 11 seconds out from the server !
    Six tests - first and last streamed media, the rest failed within the android app with a Video Player Error
    e.g.
    08-06 11:53:58.411  i: [Exo1VideoPlayer] Player state changed: 3, Restarting: true
    08-06 11:53:59.083  e: [Exo1VideoPlayer] Player error detected
    08-06 11:53:59.087  e: An exception occurred: com.google.android.exoplayer.j: java.lang.IllegalStateException
    08-06 11:53:59.089  e: Stacktrace: com.google.android.exoplayer.j: java.lang.IllegalStateException
        at com.google.android.exoplayer.p.handleMessage(SourceFile:244)
        at android.os.Handler.dispatchMessage(Handler.java:98)
        at android.os.Looper.loop(Looper.java:148)
        at android.os.HandlerThread.run(HandlerThread.java:61)
        at com.google.android.exoplayer.g.y.run(SourceFile:40)
    Caused by: java.lang.IllegalStateException
        at android.media.MediaCodec.native_queueInputBuffer(Native Method)
        at android.media.MediaCodec.queueInputBuffer(MediaCodec.java:2165)
        at com.google.android.exoplayer.w.a(SourceFile:724)
        at com.google.android.exoplayer.w.a(SourceFile:531)
        at com.google.android.exoplayer.am.a(SourceFile:128)
        at com.google.android.exoplayer.p.j(SourceFile:432)
        at com.google.android.exoplayer.p.handleMessage(SourceFile:211)
        ... 4 more
    08-06 11:53:59.212  i: [video] Error detected before playback
    Subtract 2 hours 23 minutes 11 seconds from this time to match the PMS log extracts in the table
    I am referring it to the android team but I need a sample that gives the problem
    See https://support.plex.tv/hc/en-us/articles/201035968-Generating-Sample-Files-from-Media
    @anhtuan99 investigation suspended . Waiting for a sample file
    Sorry was finding a place to upload the sample file. Here it is 100MB sample using the dd method:
    http://depositfiles.com/files/cpdiw2idq
    Thank you - I have passed the link to the android team
    The evidence was showing the problem when resuming
    Did you try when starting that same file from the beginning?
    There are some issues with the sample because dd was used - the length more than the actual clipped file
  • nebur692nebur692 Members Posts: 7 ✭✭
    The same thing happens to Me, the movies with audio TrueHD or Dolby Atmos give error.
    There could be different reasons for similar symptoms. Please raise a new forum topic with your diagnostics and screenshots - see
    https://support.plex.tv/hc/en-us/articles/201643703-Reporting-issues-with-Plex-Media-Server
    It did occur from the beginning of the movie as well as when resuming. Here's another sample video created with mkvmerge:
    https://drive.google.com/open?id=0B8bz0mbBf1djVE5UVFllb2hybEk
    Thank you
