Audio transcoding starts transcoding video with subtitles. Is a bug. Sony TV and Andoid Smart Box
chupa.livornochupa.livorno Posts: 6Members, Plex Pass Plex Pass
Good evening I have a Smart Android Box specifically for a MXQ Pro II. In the settings I selected only image formats for the subtitles but when I press play makes me transcoded to the video even though the subtitle format is SRT I believe that before the last update this did not happen. How can I fix it for Direct Play or Direct Stream? Thanks
Answers
  • chupa.livornochupa.livorno Posts: 6Members, Plex Pass Plex Pass
    edited August 2017
    Good morning, today I have had some time and I did some tests.
    I used an MKV file with H264 codec and subtitles in SRT and audio AC-3, I set the quality to "Maximum" after I set the subtitles to "only image format" after I did the following tests:
    Test 1
    Subtitle enable: ✔
    Device Support AC-3:✘
    Device Support E-AC-3:✘
    Result Video: Transcode H264 to H264
    Result Audio: Transcode AC-3 to AAC
    Test 2
    Subtitle enable: ✘
    Result Video: Direct Stream
    Test 3
    Subtitle enable: ✔
    Device Support AC-3:✔
    Device Support E-AC-3:✔
    Result Video: Direct Play
    Result Audio: Direct Play
    Test 4
    Subtitle enable: ✘
    As you can see, enabling or disabling "Device Support AC-3" and "Device Support E-AC-3" triggers transcoding for the video if a subtitling is selected, but why does audio affect subtitles? If the SRT subtitle is supported by the device and I set "only image format" it should not start the transcode
    Cunningly do some Plex developers control this situation?
    PS: Same as with a Sony TV The XE90 that when selected a DTS-HD 7.1 audio and SRT subtitles starts audio transcoding from DCA to AAC and that's fine, but also part of the video transcoding from H264 to H264
  • ShasdoShasdo Posts: 1Members
    Hi
    Does your problem has been solved?
    Because I bought last week a Xaiomi Mibox 4K and I think I have almost the same problem.
    I run PMS Version 1.8.4.4249 on a Synology DS412+
    I tried two different movie , each one is an MKV with embeded SRT.
    Movie 1: H264 + AAC
    Subtitle enable: ✘
    Movie 1: H264 + AAC
    Subtitle enable: ✔
    Movie 2: H264 + DTS
    Subtitle enable: ✘
    Result Audio: Transcode DCA -> AAC
    Movie 2: H264 + DTS
    Subtitle enable: ✔ (same with sidecar SRT)
    Result Video: Transcode H264 -> H264
    Did you find a solution?
    Thx
