HD HomeRun Connect connection
thalfmanamiga@gmail.comthalfmanamiga@gmail.com Posts: 24Members, Plex Pass Plex Pass
Thinking of changing tuners due to some persistent Live TV/DVR issues with the USB option. My question: If the router is in one room and the antenna is in another (many rooms away), how do I add the Connect to the system?
  • SX86SX86 Posts: 16Members, Plex Pass Plex Pass
    I have my antenna on my roof outside, and my HDHomeRun Connect is in my basement, next to the router. If you can get a long enough coaxial cable going from your antenna to your Connect, then you are fine. You could also do it with a long ethernet cable....but I prefer the coaxial cable for my setup.
    Hope that helps!
