Issue with remote streaming from Channel (HTTP Live Stream)
brandonmbrandonm Posts: 8Members, Plex Pass Plex Pass
There seems to be an issue only when trying to play remotely. I have included 2 log files from that same Roku player. One remote connection and one lan connection. You can see the paramerters are almost exactly the same execpt for "location => lan" header getting added to the local players request.
I am also including a test plugin that will stream a 10 second video from my server that will allow anyone to replicate the issue (hopefully)
These log line for the remote log seems intresting. Why is the BW exceeded so high?
Aug 27, 2017 11:53:04.426 [0x70000a29a000] WARN - Streaming Resource: Bandwidth exceeded: 2147483647 kbps > 796015 kbps
Aug 27, 2017 11:53:04.426 [0x70000a29a000] DEBUG - MDE: analyzing media item -1
Aug 27, 2017 11:53:04.426 [0x70000a29a000] DEBUG - MDE: Test: no direct play video profile exists for hls/mpegts/h264
Aug 27, 2017 11:53:04.426 [0x70000a29a000] DEBUG - MDE: Test: no direct play video profile exists for hls/mpegts/h264/aac
Aug 27, 2017 11:53:04.426 [0x70000a29a000] DEBUG - MDE: Test: selected media 0 / -1
Aug 27, 2017 11:53:04.426 [0x70000a29a000] DEBUG - Streaming Resource: Changing decision parameters to fit bandwidth limit of 8000kbps
It will loop trying reducing playback quality then eventually error with:
Aug 27, 2017 11:53:04.437 [0x70000a29a000] DEBUG - Streaming Resource: Reached Decision id=-1 codes=(MDE=3001,Cannot direct play this item. Required bandwidth is not known and only kbps is available. General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. No direct play video profile exists for protocol hls, with container mpegts, and video codec h264. Transcode=4004,Not enough bandwidth for any playback of this item. Cannot convert to below minimum bandwidth of 103kbps.)
As you can see from the log I am using Plex Media Server v1.8.1.4139-c789b3fbb on Mac OSX 10.12.6 (Sierra)
Answers
  • brandonmbrandonm Posts: 8Members, Plex Pass Plex Pass
    Bumping with the hoping that someone from Plex will try to replicate with my Test channel and see the remote streaming issue.
