Sub-Zero not showing "Television" library
theonejackdry@gmail.comtheonejackdry@gmail.com Posts: 8Validating, Plex Pass Plex Pass
edited September 2017 in Channel Plugin Development
The Sub-Zero plugin works great to get subtitles for my movies but it doesn't seem to "see" the TV type libraries. Is there something I missed or is that normal?
I saw someone else posted that question but I saw no answer so I'm posting my own question.
Best Answers
  • theonejackdry@gmail.comtheonejackdry@gmail.com Posts: 8Validating, Plex Pass Plex Pass
    edited September 2017 Accepted Answer
    I think I may have found the solution to the issue. In the general Plex Settings, under Agents/ Shows/ TheTVDB, the Sub-Zero Subtitles box wasn't clicked.
    I went back to the Sub-Zero plug-in settings and now it "sees" TV shows.
    I hope that can help others.
    Accepted Answer
    Thanks a lot!
Answers
    Accepted Answer
    Thanks a lot!
