[Transcoder] [eac3_eae @ 0x14d9400] EAE timeout! EAE not running, or wrong folder? Could not read
RonUSMCRonUSMC Posts: 2Members, Plex Pass Plex Pass
edited September 17 in Docker
Hi, I've read the other threads but it seems that this is a bit different? What I have not tried yet is to set the /tmp folder outside of Plex yet as I am using the official docker image and that setting wasn't available, so before I went messing around I wanted to post here.
I did verify my inotify,
# increase the number of inotify watches
fs.inotify.max_user_watches=524288
I searched logs and found these entries.
ERROR - [Transcoder] [eac3_eae @ 0x14d9400] EAE timeout! EAE not running, or wrong folder? Could not read '/config/tmp/pms-437bf3b7-8d0c-4e31-b04a-af60c6ab03c5/EasyAudioEncoder/Convert to WAV (to 8ch or less)/15p643li5cc3nt0keauc61wn_28028-1-0.wav'
ERROR - [Transcoder] [eac3_eae @ 0x14d9400] error reading output
ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
DEBUG - Auth: Came in with the master token, authorization succeeded.
DEBUG - Request: [127.0.0.1:47108 (Loopback)] PUT /video/:/transcode/session/15p643li5cc3nt0keauc61wn/9feb1bd3-633b-49fa-9432-714a5787ac81/progress?progress=-698740304058.2&size=-22&remaining=-1&speed=-3200635895808.0 (13 live) Signed-in Token (RonUSMC)
DEBUG - Completed: [127.0.0.1:47108] 206 PUT /video/:/transcode/session/15p643li5cc3nt0keauc61wn/9feb1bd3-633b-49fa-9432-714a5787ac81/progress?progress=-698740304058.2&size=-22&remaining=-1&speed=-3200635895808.0 (13 live) 0ms 326 bytes
ERROR - [Transcoder] [eac3_eae @ 0x14d9400] EAE timeout! EAE not running, or wrong folder? Could not read '/config/tmp/pms-437bf3b7-8d0c-4e31-b04a-af60c6ab03c5/EasyAudioEncoder/Convert to WAV (to 8ch or less)/15p643li5cc3nt0keauc61wn_28028-1-1.wav'
The only logs that I could see that were different..
DEBUG - Job running: EAE_ROOT='/config/tmp/pms-437bf3b7-8d0c-4e31-b04a-af60c6ab03c5/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/798f007-1247-linux-ubuntu-x86_64/' XDG_CACHE_HOME='/config/Library/Application Support/Plex Media Server/Cache/' XDG_DATA_HOME='/usr/lib/plexmediaserver/Resources/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'h264' '-codec:1' 'eac3_eae' '-eae_prefix:1' '4cvjju66w5cyu20kzbw5pef9_' '-noaccurate_seek' '-i' '/tvshows/...' '-map' '0:0' '-codec:0' 'copy' '-map' '0:1' '-metadata:s:1' 'language=eng' '-codec:1' 'aac' '-ar:1' '48000' '-channel_layout:1' 'stereo' '-b:1' '256k' '-f' 'dash' '-min_seg_duration' '5000000' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/4cvjju66w5cyu20kzbw5pef9/92b1e4e5-bc13-4788-baad-54f8a5502838/manifest' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' '-movflags' '+faststart' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/4cvjju66w5cyu20kzbw5pef9/92b1e4e5-bc13-4788-baad-54f8a5502838/progress'
ERROR - JobManager: child process returned: 13 (Permission denied)
Which leads me to believe there is a permission error somewhere? I haven't done any configuring on this, even the inotify entry was already present.
running official docker, up to date, pms 1.8.4.4249
Looking in the docker log, I found this...
Sep 17 06:25:01 Tower /USR/SBIN/CRON[5995]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
tail: ‘/var/log/syslog’ has become inaccessible: No such file or directory
tail: ‘/var/log/syslog’ has appeared; following end of new file
I don't know if that is relevant or not.
Oh, system specs ..
UnRaid on Ryzen 5 1600 w/ 16g RAM. PMS and all the dockers are on an SSD cache drive.
Answers
