Our forum migration to Discourse will be going on starting late today June 19 to 21. During the migration, the forums will be read-only, except for a single temporary forum (which will not be getting transferred). Read our announcement post here for more information https://forums.plex.tv/discussion/319354/well-be-moving-the-forums-to-discourse-heres-the-scoop/
Hey folks, there is a new Podcast category for forums https://forums.plex.tv/categories/podcasts
Change default audio stream
reddwarfcrewreddwarfcrew Posts: 648Members, Plex Pass Plex Pass
One of the good things about roku, is that if you choose an audio stream other than the first, then it will always use that stream type in other media by default.
Most of my media has 4 streams:
1 - AAC 2 channel Dolby Pro Logic
2 - AAC 5.1 DD
3 - AC3 2 channel Dolby Pro Logic
4 - AC3 5.1 DD
Is it possible to amend the PfK config file to default to AC3 5.1 DD if it exists and if not fall back to the first stream?
Cheers.
