Roku Plex Ac3 audio sync issues
phimdo2003phimdo2003 Posts: 2Members
I just got a new Roku Premeire+ and running plex. aac 5.1 and DTS 5.1 works great on it but whenever i try a ac3 5.1, there is about a 3 sec audio sync issue (sound comes firdst before video). These files works fine on plex for Chromecast and Amazon fire stick.
I tried every possible combinations of direct play / directstream options in the roku plex but nothing fixes the issue. I tried changing the audio options on Roku and some options either did not do anything or gave no audio.
Hdmi plugs directly in my receiver Onkyo TX-NR646. Running the latest Plex Media Server on a laptop supporting a 4th gen i5 processor. It can transcode most of everything I throw at it including multiple HEVC streams.
I love the roku in both video quality and processing speed. I also like how it can play DTS without transcoding it. It's just that I have many files with ac3 audio and this is a major issue. I hope there is a simple work around that does not involve changing the audio format to stereo to force a transcode to stereo. I do not mind forcing a transcode from ac3 to aac but do not know how to do it.
Comments
  • JuiceWSAJuiceWSA Posts: 7,809Members ✭✭✭✭✭
    Roku has issues with lips and the sound of the words living in the same zip code.
    Here's hoping Windows 8 for Roku helps - but I have my doubts.
    I was watching a program last night (Direct Play, no less) - lips and words got all out of whack - switched to PMP to finish the program and all was well.
    The best you can hope for at this time is a 'backup plan'.
    Roku has an index finger buried up a nostril to the second knuckle and they're diggin' for gold.
    Tony
    FileBot For Easy Plex File Naming: http://www.filebot.net/
    Automated Plex Naming With Filebot: https://forums.plex.tv/discussion/191687/plex-naming-schemes-for-filebot
    Plex Friendly Handbrake Guide - DVDs/BluRays: https://forums.plex.tv/discussion/comment/1335697/#Comment_1335697
    Plex Clients: AFTVs, Androids, PMP, Rokus (running RARflix: http://mkvxstream.blogspot.com/2014/09/roku-plex-setup-guide.html ) Link May Work - May Not
  • nagle3092nagle3092 Posts: 70Members, Plex Pass Plex Pass
    Same issue here, works fine in emby for roku for me though so my guess is the plex app.
  • phimdo2003phimdo2003 Posts: 2Members
    I figured it out. It may not be a perminant fix up when it acts up, unplug it for about 10 sec and plug it back it. Everything including ac3 works again for a few days before it get off sync again. Unplug again to temporarily fix issue. Not perfect but I can live with that
  • HandyFlanaganHandyFlanagan Posts: 2Members, Plex Pass Plex Pass
    Same problem with Roku Ultra. Firmware 8.0.0 build 3138-46.
    Unplugging didn't seem to help.
  • clwillclwill Posts: 5Members, Plex Pass Plex Pass
    I have this same problem. Only seems to be a problem with AC3. Happens on my Ultra, Premier, and two Roku3s. Haven’t tried the unplug/replug trick. But if I force a transcode out of AC3, it works perfectly. Come on Roku, fix this!!
