Hyper-V PMS: RemoteFx in Discrete Mode using Hardware Transcoding Question...
johnnycolejohnnycole Posts: 16Members, Plex Pass Plex Pass
Has anyone used a high-end graphics card in discrete mode and seen any advantages in a virtualized PMS box? My Plex server currently has 38 cores assigned (the Hyper-V 2016 host is running a single Xeon E5-2699 v4 processor, and hosts several other virtualized servers) and I have absolutely no issues transcoding (software) any types of files (to include HEVC). My average is about 8 concurrent users, mostly transcoding (and the CPU never breaks a sweat). Before I go drop more money I would like to know if anyone is doing this yet (using a virtualized high-end graphics card in discrete mode, and seeing advantages using hardware transcoding). Thanks!
Best Answer
«1
Answers
  • ChuckPAChuckPA Posts: 20,118Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    Does the VM have direct and exclusive access to the hardware? If not, any efforts will be in vain.
    Please DISABLE Verbose logging until requested
    Please search before posting
    Primary support forums: Linux, Synology, and QNAP
    Please remember to report back. This benefits others.
    Useful links
     Installation and Basic Setup |  Media Preparation (How to name your media files)  |  Linux Permissions
     Handling TV Specials | Handling Movie extras  |  Nas Compatibility List
     Reporting Plex Server issues | Plex Media Server FAQ | Linux Tips
    Other useful guides: Local Subtitles | The Plex "dance" | Synology FAQ | PMS Release Announcements
    Hosts: Fedora, QNAP, Synology, most Linux distros in VM
    No technical support via PM unless offered
    Please remember to mark the appropriate answer(s) which solved your issue.
  • johnnycolejohnnycole Posts: 16Members, Plex Pass Plex Pass
    edited October 2017
    Yes, that is what I meant by saying discrete mode...
    https://docs.microsoft.com/en-us/windows-server/remote/remote-desktop-services/rds-graphics-virtualization
    ...and this would be the card I would use (dedicating one GPU and 16GB of GPU RAM to PMS):
    https://www.amd.com/en-us/products/graphics/workstation/radeon-pro/duo
    Let me move this to Windows forum. You'll have proper help from those there. I'm just a Linux guy ;)
    Useful links
    No worries...this question could also relate to Linux as well, Chuck (discrete mode, aka SR-IOV is a beautiful thing). It doesn't even have to be Microsoft's solution (for the Hypervisor).
    Linux won't give you that level of control over the devices unless you do a whole lot of kernel config and custom software. As soon as you do that, you push yourself into a non-supportable state (obvious reasons).
    The fundamental problem you're going to face is in libva if you use Linux. Hardware transcoding is currently setup / implemented for single-resource home user. It is for the single user. Not something as massive as I believe you're thinking.
    Useful links
    edited October 2017
    Oh wow...just did some reading about that, and am very surprised that the Linux kernel doesn't natively support this feature (was just on the Red Hat message board). I'm very excited about GPU hardware transcoding, and with SR-IOV, the card is directly attached to the virtual machine (just like a physical box). Because, in the greater scheme of things, no average Joe buys a 4300 dollar processor to just run Plex...LOL ;0)
  • AchillesAchilles Posts: 2,221Members, Plex Pass, Plex Ninja Plex Ninja
    You are essentially asking if anyone has every pass-through the GPU of a virtualized high-end graphics card to a Hyper-V guest--correct?
  • cayarscayars Posts: 4,554Members, Plex Pass, Plex Ninja Plex Ninja
    With Windows 2016 as the host and Windows 2016 as the guest Plex should work with that card.
    I played with a similar setup in a VM during hardware beta and it did work for me. However, nothing is guaranteed of course and it's not like this is going to be a standard setup that Plex will test for.
    I'm assuming you are thinking of buying the card for other purposes and just want to make use of it as well for Plex. If not and you are planning to use it only for Plex, make sure you can return it just in case.
    But it should work if the host is Windows 2016. ffmpeg (what our transcoder is based on) can do this as well in the VM in discrete mode.
    However, your server is probably handling the load fine now with just the CPU so why add the GPU?
    Carlo
    11.2K+ Movies, 410 Shows - 34.2K+ TV Episodes, 490 Christmas Movies, 445 Documentary, 290 3D Movies, 1300 Sports Matches, 1280 Educational Videos, Premium Music: 215K+ Tracks, 900 GB Plex Meta-Data. 6 Network Cable Tuners.
    Thread on my setup with some tips and tricks: https://forums.plex.tv/discussion/131308/cayars-setup-walk-through-and-some-tips-and-tricks/p1
    edited October 2017
    "You are essentially asking if anyone has every pass-through the GPU of a virtualized high-end graphics card to a Hyper-V guest--correct?"
    No, that is totally possible, and not just with video cards (like I stated before, I'm a big fan of SR-IOV). I'm wondering, since hardware transcoding is no longer a feature that is only offered by a beta version of Plex, if anyone has used this type of scenario successfully, and seen results (that can compete, and hopefully are better than software transcoding). I just lowered my electric bill by almost 150 bucks a month, because I was running a dedicated i7 6700 PMS box that was pegged at 100% all the time (by adding 5 additional friends to my Plex pool). Damn mini case burned your fingers if you touched it for more than a second. I consolidated my Hyper-V host and my PMS box (from two boxes) to a single server solution...however, it would be great, in the near future, if (whether virtual or physical) a PMS server utilizing hardware transcoding could be built based on a GPU...especially as UHD starts becoming the norm, and compression can be tamed using a graphics card vs CPU (similar to the bitcoin mining situation). My question is based on my specific environment, but since I would use a discreet "direct" connection to the hardware, it could be applied to a physical scenario as well...
    "However, your server is probably handling the load fine now with just the CPU so why add the GPU?"
    You're right...I have absolutely no problem with my current setup...but, I am interested in offloading to a GPU vs CPU. I would get the card, and dedicate half of it to PMS (if it can be exploited). My curiosity is based on this, say, 4 years from now, when (hopefully) 8k is the norm, and there is a compression scheme more demanding than h265. Is everyone that wants to stream to 10+ users using Plex going to have to buy a 4000+ dollar processor, or, a modern-day Intel Nuc Skull Canyon (smaller than an average paperback book) built around a bad-ass GPU?
    I've attached this month's data collection (from my Plex VM). I wish I had a screenshot from the month before, where the CPU table pretty much stayed at 100% for at least 18 hours a day..
    edited October 2017
    ...and I would like to ask another question (totally different topic, but just as important). Software side...any thoughts of offering the PMS backend based on a MYSQL or SQL database? This product has so much major growth potential in the near future...and whether you are using a local (on-site) or cloud solution, being able to use a fast indexed optimized (and vendor supported) database would be stellar...think of the hooks that could be built, exploiting the application data tables and metadata?! Plex could replace products like Adobe Lightroom and give birth to things like new online radio stations (for example) overnight...if it had a standardized database...coupled with GPU hardware transcoding (which could be deployed on thin clients built around a fast GPU). Plex has the potential, more so than any of their competitors, and I believe that they could (with the right resources) get into any market...from watching the morning news or last night's Simpsons on your OLED screen above the microwave in your kitchen, to running media in a 3rd grade classroom.
    It's been asked numerous times before about having a real back end SQL database.
    Best I can say is I doubt this will ever happen.
    It's a real shame too, because it would allow us to easy scale our systems to handle transcoding so much easier. You could run a couple of home computer with QSV or dedicated GPUs and be able to handle pretty much any load of family and friends. If you were into DVR you could setup a different computer for recording with real time Transcoding so all shows/movies are saved as MP4 with commercials cut.
    This would give us a lot more flexibility for sure.
    I wouldn’t see why not.
    I currently use a Skull Canyon with HW transcoding and its more than capable of handling 10+ concurrent users for H.264 encoding. I will be looking at the Hades Canyon for support of H.265.
    edited October 2017
    When I say I have an average of 8 concurrent users that’s exactly what it sounds like....I get between 15-20+ concurrent users during peak times. Most of my TV sourced media is encoded in HEVC H265....and there is plenty of media that is at 4k resolution (not to mention the DTS-HD and ATMOS audio tracks). My previous standalone PMS box was running a desktop CPU version of the 6700k...which (even with Iris hardware transcoding) felt like it was going to catch on fire (temps hovered between 85-99 degrees). I merely want to know if anyone is running hardware transcoding in a virtual environment successfully, using discrete addressing, aka SR-IOV (and it is proven better than software decoding). Are we there yet?
    @johnnycole said:
    When I say I have an average of 8 concurrent users that’s exactly what it sounds like....I get between 15-20+ concurrent users during peak times. Most of my TV sourced media is encoded in HEVC H265....and there is plenty of media that is at the 4K rolution (not to mention the DTS-HD and ATMOS audio tracks). My previous standalone PMS box was running a desktop CPU version of the 6700k...which (even with Iris hardware transcoding) felt like it was going to catch on fire (temps hovered between 85-99 degrees). I merely want to know if anyone is running hardware transcoding in a virtual environment successfully, using discrete addressing, aka SR-IOV (and it is proven better than software decoding). Are we there yet?
    1. Been there the whole way.
    2. Yes I have seen it done but you will not be able to utilize more than one passthrough GPU with Plex
    3. Not sure one GPU will scale to 15-20+ concurrent users as software decoding can with the CPU you have
    4. Software transcoding quality is currently deemed better than HW transcoding quality. Platform video acceleration libraries and hardware drivers are the variable determining factors here.
    edited October 2017
    Thanks Achilles...best answer so far! I mentioned Bitcoin mining earlier in the thread, which can be compared to Plex hardware transcoding...and from the sounds of it, even though it is now a standard feature, it still has not been optimized to take full advantage of the GPU hardware (processor, RAM, extensions, etc). I guess I’m fishing...can someone from the Dev team tell me (us) where their bottleneck is? If we give PMS a top of the line graphics card, capable of rendering raster graphics at 8k+ why can’t it do the same with a compressed flat file? I’m not trying to insult the Plex coders, however, it would be great to understand if there is a current limitation based on a codec or vendor extension (that’s limiting the hardware transcoder). Please keep in mind, I’m not talking about embedded graphics in this scenario, but a beefy card with crunching potential (heavy emphasis regarding the Bitcoin mining comparison). I seriously do believe that 8k will be here in the near future <5 years...and even H265 (which to me, is almost as important as the invention of the original MP3 compression scheme) will be replaced by something even more complex. I would even offer some of my free time to champion this effort (if there is a limitation that is vendor based). Like I said...I’m kinda fishing (LOL) and would love some feedback...is the hardware transcoding using pure OpenCl and CUDA...are there plans in the future to utilize SLI and Crossfire...Is Plex (as a company) working with Nvidia and AMD (game development shops do, and drivers are released to take advantage of code for certain games based on their rendering engine)? Thanks guys!
    Honestly the bottleneck is in your files. :) You're feeding it files that almost certainly have to be transcoded in order to be viewed by your friends. If you created a direct playable version in MP4 container using h.264 with a default audio track of AAC stereo (plus additional audio tracks) you would save yourself from having to transcode a large portion of the time and the quality would be better as well.
    I used to use a dual XEONs with 12 cores each (24 cores or 48 virtual cores) as my Plex server. I started converting my media and now have everything in my sig in a direct playable format and haven't looked back. I now run my Plex server on a 1st gen i7 at 2.8Ghz with 8 virtual cores) and an older AMD R9 280x GPU and it works just fine.
    I have 4K libs (mostly h.265) and also 1080 libs. Any movies in the 4K libs will also be encoded for 1080 as well. I only share the 4K lib to people who can direct play it and of course have 4K TVs. If I see them transcoding I stop sharing that library with them.
    Something to keep in mind about the way Transcoding works in Plex in general. When you have a file that needs real-=time transcoding it doesn't start a file transcoding and let it go until finished. It transcodes only enough to keep the buffer filled on the client side. So if your CPU was fast enough it's quite possible you could be streaming to 5 clients but only 1 transcode would be taking place at any time since as soon as it's transcoded enough it shuts the transcode down and waits. When the next client needs more data it will transcode more, fill the buffer and wait again. Of course on slow machines it might have to transcode them all at the same time just to keep up. But on fast machines it can seem like the CPU is hardly doing anything and mostly waiting.
    Enter GPU, same thing. So lets imagine you have a card that only supported 2 encodes at the same time. That doesn't mean you can only stream to 2 people using it. Since it transcodes, fills the buffer and stops it's quite possible to support 6 to 8 streams only being able to transcode 2 streams at the same time. Think about it. If you could only do 2 encodes at the same time but each was 10x real-time speed (total of 20x) in theory you could support 20 streams (lets call it 12 to 15 to be safe).
    Don't get caught up in the math from above as it's made up just to explain how it could work. Every system is different as it depends on the hardware and the media it has to start with. But I just wanted to point out that X concurrent transcodes can support many more streams on fast hardware due to the pausing during encoding once you get ahead of what's needed.
    Personally after having been down the path of using enterprise equipment for Plex and having used lower end "home" equipment I wouldn't go back to enterprise class as it's just not worth it $ wise.
    I could easily build 3 or 4 cheap computers running as standalone Plex servers each with it's own dedicated consumer class GPU (or use QSV) pointed to the same media. I then could assign users to a particular Plex server to balance the load. Now I have redundant backup servers as well.
    I too used to be roughly where you are now streaming wise. I used to share with a ton of people, from guys I worked with to guys I shoot with to friends and family. Then my dad had friends and my kids had friends. I also had a few people from here in the forums as well. But then people started sharing their accounts with other members of their family and I would see 3 or 4 streams coming from the same account on different IPs. People I didn't know and I wasn't planning on being their "Netflix" so I sent out warning to people and then started to remove people who were abusing my "goodness" sharing with them. Over time I downsized who I share with and I'm back to close friends and family.and I couldn't be happier.
    But anyway even on the 1st gen i7 it would stream to a dozen people. That was before we had HW encoding. So knowing what I know know I'd go for multiple smaller computers and segment users vs a big expensive to upgrade computer for running Plex. EG you could easily build 4 nice i7 machines for what that GPU will cost. The i7s would have QSV and would support HW encoding and could easily handle 40+ users without an issue. Plus you would have duplicated hardware and redundancy.
    Just a thought,
    Carlo
    This is an interesting thread. It's been interesting to read along.
    Vmware introduced SR-IOV in Vsphere 5.1 in 2012. It's 5+ year old tech. It may be new to some but we call it for what it is "PCI passthrough" and everyone does it. It's been built into publicly available VirtualBox for a long time.
    Comparing Bitcoin to Video isn't a valid comparison. Comparing gaming to video isn't valid either. One is based on pure flat matrix math, gaming is parallel 3D solid modeling, while video is a set of FFT sequences on ever-changing input data. Games objects are based on static models. While one can use OpenCL or Cuda for mathematics or game modeling (prime number proofs is an excellent example and what I do as my hobby), easily broken into smaller independent task blocks, with the blocks reassembled upon completion , video is not the same. Video frames are intra- and interdependent where the output of one is needed as input for the next on multiple axes (the FFTs) . You're asking for a maturity level which does not yet exist in the domestic video world.
    Your analogy using SLI/Crossfire, where game model objects are independently rendered 3D solid models and 'dropped' into the composite video frame, is not applicable. The closest you could hope for in this video world is a multi-stage pipeline where video enters one end of the pipe, is processed as it traverses the pipe, and exits the pipe upon completion. The level of software sophistication needed to accomplish this is is not readily available (free) to the general public. Yes, FFMPEG does support OpenCL/Cuda but not at the level you are asking and probably won't for some time as FFMPEG is a volunteer effort.
    Regarding 8K video. "5 years away" is an eternity. It's at least 2 generations of silicon away. 8K content is even further away as it would require 12K or 16K masters be produced. Sure, it's possible to do 8K gaming or computer workstations but Hollywood (which includes the consumer video player manufacturers) isn't even doing any 8K filming yet. They need to upgrade every step in that process from cameras, to production equipment, to storage, and to the players consumers purchase. Having an 8K monitor / TV is quite arguably meaningless without the video to fully utilize it. Sure, one could do upscaling in the display but it's interpolated data, not original content data.
    Comparing MP3 compression to H.265 isn't valid. One must distinguish between 'more compression" vs 'better compression'. WAV->MP3 falls into the 'more compression' class. HEVC falls into the 'better compression' class. MP3 made the audio softer. The intent of HEVC is to reduce the total data required lower than H.264 while keeping those nice crisp edges, which it does nicely, but at the cost of more difficult decode/rendering.
    Now to Plex:
    1. Speaking to Linux only: Hardware transcoding does not utilize OpenCL or Cuda directly. PMS accesses video acceleration through the VAAPI layer. What happens below that layer is invisible and immaterial to PMS.
    2. Plex doesn't publish roadmaps.
    3. It's not about coding existing technology. It's about creating new technology. Trying to predict when genius will strike can't be done. One cannot reliably predict those "Today I will be brilliant" days when the stars align and genius strikes.
    4. We are monitoring the progress of Intel's VAAPI 2.0.0 development. Engineering will be evaluating when it becomes a firm, final, release. This is because the API & ABI (most importantly) has changed (per Intel development themselves on 01.org). Upon release, there will be considerable NRE investment to up-rev to 2.0
    Useful links
    I hear ya...however, I would never "compromise" my media. It is actually about the math (at least to me). The resolution, encoding, number of sound channels, bitrates, etc...I have spent the last 30+ years building my entertainment system (paid more for my first large format TV than I did for my first car...both in the early 90's). Have you seen a classic movie remastered, going from <320 to 1080? It's beautiful. I don't believe in optimizing my media to work across different hardware platforms, I want the file as compressed as it can be while being as close to lossless as possible. I understand, that I am a minority, and most of your movie/music/hifi fanatics use optical media vs disk storage. I've been collecting media from the phone lines since 1982...and still actually have my original first MP3 CD (the year the compression format was released) 169 songs...and most people back then thought that was impossible. Whether I'm watching a movie from my PMS server in my Man Cave with 16 speakers on a 4k screen (not gonna say how big, because it already feels like I'm already kinda boasting), or watching 1300 miles away on my Mom's 5.1 Bose system on a 65 inch 1080p tv in her living room, I want the best experience. Not to mention, we have some really cool directors nowadays that are shooting great new films with really cool 4k RED camera's, and now let's throw in 3d (and double the resolution). I guess you could use that feature of Plex, aka Optimize (that I wouldn't dare to use). Seriously, no offense...not trying to be a snob!. Lastly, I would like to add, because I have to expose my PMS to the internet, I wouldn't dare let Plex have ANY write privileges to any of my media (which sucks because I can't use a lot of the cool sync features). But hey, no code is perfect, the db structure is based off a giant tree and folder map...and since folks can basically hack anything nowadays, I would like to keep my media (and all my other data safe and sound). Full circle...just trying to be an IT Fortune teller here...and am interested in taking an expensive graphics card and be able to be a mini Netflix provider to my friends and family (while providing the highest resolutions and as many audio channels the film provides). Using /exploiting the hardware is key...hat's off to the Plex development team because at least they figured out to offer multithreaded software transcoding...
    Yes, It's all about the math. It sounds like you and I have been around this stuff since flyback transformers where the first thing you learned NOT to touch >:)
    What I find most interesting is how long it took for this tech to make it to consumer. I had a stint building full fidelity flight trainers complete with video and graphic rendering (aka.. early CGI)
    I use Linux because I have that absolute protection afforded by the OS. PMS runs as an unprivileged user; files are set read-only to PMS. There is also a full mirror in case I mess up and a full offline backup set of everything.
    Useful links
    edited October 2017
    Why can't you do both at the same time?
    That's the thing. If you want the absolute best video you can't transcode it on the fly. You have to encode it up front in the format that will be needed. Any time you transcode on the fly (CPU or HW) you ARE loosing detail.
«1
This discussion has been closed.
