Problem running Plex Media Server QNAP
TPwireNASTPwireNAS Posts: 2Members
I have been update to last version of PLEX media server for QNAP. Before this update i could use PLEX media server without problem. However, when I click:
Is redirected to the following page:
But this page is not the page of Plex Media Server.
Any help please?
Best Answers
  • moody_bluemoody_blue Posts: 3,210Members, Plex Pass, Plex Ninja Plex Ninja
    1. QNAP model ?
    2. Did you remove the previous PMS version, or did you install over the existing one ?
    QNAP TS-253A 4G QTS + PMS + QPython2 + PlexConnect 0.6
    TV Sony KDL-32V2500 (720p) + aTV3 Rev. A firmware 7.2.2 + Denon AVR-1604 A/V Receiver 5.1 + Harmony Touch
    Portables 1x iPad4, 2x Android phone, 1x Android tablet, 2x PMP on Win10
    No support via PM unless requested by me
  • TPwireNASTPwireNAS Posts: 2Members
    1. QNAP Model: TS-453B mini 8GB ram
    2. I installed over the existing one. However, when i saw that it not run properly, i uninstalled and i installed the last version.
  • MwC_TrexxMwC_Trexx Posts: 221Members, Plex Pass Plex Pass
    edited October 2017
    @moody_blue said:
    4. Finally, you cannot have container station installed, and in case you have more than one network interface active, take a look at Q21 in FAQ
    That actually isn't a true statement. I have been running PMS on my NAS w/Container Station also present for months with no issues.
    Now there are some things I would recommend doing such as defining the LAN Network that help alleviate potential issues, but assuming your networking is properly configured (big assumption I know in most cases) Plex & container station can co-exist just fine.
    Model: TS-877-1600
    QTier (SSD): [RAID-1] 2 x 525GB Crucial MX300 m.2's
    QTier (HDD): [RAID-5] 6 x 3TB HGST DeskStar NAS
    RAM: Kingston HyperX Fury 32GB 2 x 16GB DDR4-2666 PC4-21300 CL16
    GPU: EVGA GeForce GTX 1060 SC GAMING, ACX 2.0 (Single Fan), 6GB GDDR5
    UPS: CyberPower AVR1350
    Media Boxes: Nvidia ShieldTV Pro (4K), AppleTV 4, Roku Stick, FireStick Gen1
    Model: TVS-673 32GB Test Box
  • ChuckPAChuckPA Posts: 21,083Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    edited October 2017
    I will add the do co-exist fine. PMS, container station, and virtualization station.
    The most important piece of the puzzle is the use of a Virtual Switch. When a V-switch is used, the IP is moved from the actual adapter to the outer edge of the V-switch. Doing so isolates the container station virtual adapters / net from the physical which is then mapped into the V-switch. The end result is a single, proper, IP for PMS to see.
    Please DISABLE Verbose logging until requested
    Please search before posting
    Primary support forums: Linux, Synology, and QNAP
    Please remember to report back. This benefits others.
    Useful links
     Installation and Basic Setup |  Media Preparation (How to name your media files)  |  Linux Permissions
     Handling TV Specials | Handling Movie extras  |  Nas Compatibility List
     Reporting Plex Server issues | Plex Media Server FAQ | Linux Tips
    Other useful guides: Local Subtitles | The Plex "dance" | Synology FAQ | PMS Release Announcements
    Hosts: Fedora, QNAP, Synology, most Linux distros in VM
    No technical support via PM unless offered
    Please remember to mark the appropriate answer(s) which solved your issue.
