Plex DVR, Trying to watch Live TV but get error "Unable to tune channel (no parts)"
BradNolanBradNolan Posts: 2Members, Plex Pass Plex Pass
Using Version 1.9.4.4325 on Ubuntu with an HDHomeRun Connect.
See screen shot
it also looks like the same reason the recording was aborted for this show, see below screen shot
Please advise on further steps to diagnose problem.
Brad Nolan.
«134
Answers
  • chrisott2chrisott2 Posts: 2Members, Plex Pass Plex Pass
    edited November 2017
    I'm experiencing the same issue. HDHomerun on Windows 7.
  • awildmanawildman Posts: 1Members, Plex Pass Plex Pass
    me, too. on Ruku and AppleTV.
  • FrisosoulFrisosoul Posts: 1Members Plex Pass
    Here as well. Avermedia AVerTV Volar Hybrid Q running on Windows 10.
  • amir.mazoveramir.mazover Posts: 5Members, Plex Pass Plex Pass
    Same here , with error code (-1). HDHomerun, rasplex.
  • mevel.is@gmail.commevel.is@gmail.com Posts: 1Members, Plex Pass Plex Pass
    Same issue. Nvidia Shield TV 2017, Hauppauge WinTV DualHD. Finds all the channels but for the most part "unable to tune channel' when trying to stream directly or via web browser. TV Singal from antenna is fine (external house antenna) as I was using it on a XBMC box (before it died).
  • asriznetasriznet Posts: 10Members, Plex Pass Plex Pass
    Same issue here...
    PMS_Plexpass: Version 1.9.6.4401
    FreeNAS 11 Jail
    HD Homerun Connect
    Live TV Plays fine directly with tuner.
  • mayesesmayeses Posts: 2Members, Plex Pass Plex Pass
    I have a little script I can run on my linux laptop outside of Plex just to test tuning. It uses hdhomerun_config commands to 'tune' to a local channel, forks vlc the points the tuner at vlc.
    leem@debris:~/bin$ tune-hdhr -c 2
    Will tune 39 prog 1 on new (104DCE10) and point at VLC on 192.168.1.65:1235
    ERROR: resource locked by 192.168.1.3
    Looking at the plex server (192.168.1.3) status page on the web interface there is no activity, but the server still seems to have the tuner locked from a previous live session.
    It'll probably clear up with time (or a restart of plexmedia server, or the tuner, or...). IMO the server is a little reluctant to let go when you exit a live stream from a web client anyway. I'll try to test with Roku when I get a chance.
    Sometimes a recorded session also fails to finish transcoding and appear it in its target folder. A restart of the server fixes that as well and is all I've found to fix it. The recording shows in the web client as 100% complete.
    root@kitchen:/etc/dhcp# dpkg -l | grep plexmed
    ii plexmediaserver 1.9.6.4429-23901a099 amd64 Plex organizes all of your personal media so you can easily access and enjoy it.
    Sure enough, I waited 5 minutes (to type this! :) and now the tuner is free again for live streaming.
    Cheers!
    Lee
    Bad form replying to myself, but after some streaming/exiting/etc. from a Chrome Plex Web client I've locked up Plex DVR tuner wise. These are the 'locks' from the HDHR connect tuner plex knows of. I do not see any.
    leem@debris:~/bin$ /usr/bin/hdhomerun_config 104DCE10 get /tuner0/lockkey
    none
    leem@debris:~/bin$ /usr/bin/hdhomerun_config 104DCE10 get /tuner1/lockkey
    none
    But in the web client I get:
    Unable to tune channel (No parts) until I restart plexmediaserver. And then plex DVR is happy again!
    192.168.1.3 (streaming now to a tab)
    leem@debris:~/bin$ /usr/bin/hdhomerun_config 10151802 get /tuner1/lockkey
    none (nothing scheduled)
    leem@debris:~/bin$
    Cheers!
    Lee
  • xtreantxtreant Posts: 29Members, Plex Pass Plex Pass
    Add me to the list.. Same issue. HDHomePrime works with all other clients while failing with Plex with the error listed here
  • hamhock44hamhock44 Posts: 11Members, Plex Pass Plex Pass
    One more to the list. Iphone and web app on some live tv channels. HDHomerun Prime with PMS running on FreeNAS 11 server. Just started recently.
  • stevejsharp@hotmail.co.ukstevejsharp@hotmail.co.uk Posts: 1Members, Plex Pass Plex Pass
    Same here. Win 10 using Hauppauge Quad TV HD. Plex live TV and DVR should still be in some sort of Beta as there are so many problems and limitations.
  • gandalfnetgandalfnet Posts: 1Members, Plex Pass Plex Pass
    Me too, windows 10 HD home run Extend!
    seems to play ok on the Roku and Android
    Sounds like a plex bug to me....
    1.9.7.4460 hasn't fixed the problem for me. As a matter of fact, I started seeing the Playback Error a couple of days ago when I updated to 1.9.7.4460.
  • keytonekeytone Posts: 10Members, Plex Pass Plex Pass
    same here. can confirm that the channel comes in on the tuner with TV... just not plex
    I restarted my PMS 1.9.7.4460 running on FreeNAS 11 and now all the channels that would not tune are working on all devices.
    Update. Started getting the playback error again on one channel after restarting PMS. I did another restart and now it is working again. Not good.
  • TheBillionaireTheBillionaire Posts: 18Members, Plex Pass Plex Pass
    Same here! I am running PMS on DS918+ from Synology with two 16gb Nvidia Shields and recording from a HDHomerun Prime. I am having problems setting a recording from the Nvidia shield (nothing happens after pushing the record button). Now, I am having problems watching live TV from Plex. According to HDhomerun app, no turners are being used. Watching and recording TV works fine from within the HDhomerun app. Resetting the PMS seems to fix the problem but it's only temporary.
    PMS Setup - Synology DS918+ || Two Nvidia Shields (16gb) || Two Silicon Dust HDHOMERUN Prime w/ two Verizon Fios Cable Cards ||
  • travyshtravysh Posts: 7Members, Plex Pass Plex Pass
    And another one.
    Doesn't happen for all channels, but does for at least one. Restarting the Windows 7 plex server will fix it momentarily, but changing channels then going back will cause it to happen again.
    Signal strength and quality don't seem to affect it; happens on 617.000 MHz, 90%+ on both strength and quality. Other channels don't do this.
    And same, when plex can't tune it HDHomerun app tunes it just fine.
    Added another tuner to the server (Hauppauge Xbox One USB stick) in case it was an HDHomerun specific issue and didn't resolve it.
    Also, the problem has expanded beyond the single channel it was happening on at first to at least 3 different channels.
  • TexasSilhouetteTexasSilhouette Posts: 1Members, Plex Pass Plex Pass
    Same here, all recordings fail with "Unknown Error" and attempting to tune live TV returns "Unable to tune channel (No parts)". Plex version 1.9.6.4429 on RPi3 with HDHomeRun EXTEND. HDHomeRun app has no problem tuning/watching channels.
«134
