Artifacts, weird colors and generally horrible picture when playing 4K material on samsung 2017
RockStarRockStar Posts: 2,053Members, Plex Pass Plex Pass
I have trouble streaming 4K material using Plex on my MU7005 (MU8000 in the US). Do I need to do anything with the profile or is this a general problem with these TVs?
Mediainfo (MKV container):
Video
Format : V_MPEGH/ISO/HEVC
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2h 6mn
Bit rate : 13.4 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Bits/(Pixel*Frame) : 0.068
Stream size : 11.9 GiB (95%)
Dear Lord. If we give you Lady Gaga and Nicki Minaj, would you consider sending us back Dimebag Darrell?
Best Answer
Answers
  • DanJDDanJD Posts: 12Members, Plex Pass Plex Pass
    what's your setup and connectivity between TV and media server?
    I've seen this on some recent releases.
    Media Room - Work In Progress
    Living Room - Samsung UE65KS9000 | Sony STR-DN1080 | B&W CM9 S2 + Audica CS System 4 | Nvidia Shield (PMP) | Sonos Bridge | PlayStation 4, XBOX ONE, Xbox 360 Elite, Nintendo Wii, Steam Link | Devolo AC1200+
    Kitchen - Samsung UE65F9000 (SEK-3500) | Yamaha RX-V675 | Sonos Play 5 | Devolo AC1200+
    Study - PC (ASUS Maximus Hero VIII, Intel Core i7-6700K, Corsair H100i, Corsair Vengance LPX DDR4 - 16Gb, Zotac GeForce GTX 980 Ti AMP Extreme, Samsung SSD 850 PRO's, Windows 10 x64 Professional) | BT Infinity 2 | Cisco ASA | Cisco 2960X | QNAP 1070Pro (4.2.3) | Devolo dLAN 1200+ Wi-Fi AC
  • RockStarRockStar Posts: 2,053Members, Plex Pass Plex Pass
    edited November 2017
    Crazy fast overpowered pc and gig LAN. The problem is either in the files or the TVs / Apps filesupport, not the setup. Some files work, some dont. Its hit or miss really.
    You are right! Thank you so much! Everything with AC3 seems to play fine (Direct Plays), anything else(?) gets Direct streamed and with a horrible, artifact filled image.
    Thank you so much for figuring this out for me!
    no problem, you might want to follow my post about getting plex to stop transcoding.
  • e916mte916mt Posts: 1Members, Plex Pass Plex Pass
    Hi, I am having the same problem as RockStar. @DanJD can you check the link for your post is the right one? It's going to TRUEHD Passthrough issue, not how to get Plex to stop transcoding.
    Sorry for the basic question, but should I be looking for entries like the following to see if transcoding is taking place?
    [Transcoder] Video (decision) options
    INFO - [ui-safari-tizen] hasMDE: 1
    INFO - [ui-safari-tizen] directPlay: 0
    INFO - [ui-safari-tizen] directStream: 1
    This plays fine:
    Codec: H264 - MPEG-4 AVC (part 10) (avc1)
    Resolution: 3840x1602
    Display Resolution: 3840x1600
    Frame rate: 23.976216
    Decoded format: Planar 4:2:0 YUV
    Audio: TrueHD 3F2M2R/LFE 48000 Hz bits per sample 32
    This is terrible:
    Codec: MPEG-H Part2/HEVS (H.265)
    Resolution: 3840x1632
    Display resolution: 3840x1606
    Decoded format: Planar 4:2:0 YUV 10-bit LE
    Audio: DTS Audio 3F2R/LFE 48000 Hz 1536 kb/s
    Many thanks
    Hi, I suspect the issue is because its a 10-bit file, only 8-bit is supported under direct play, meaning it will be transcoded by Plex which in all situations tested by me is unusable...
