Hey folks, there is a new Podcast category for forums https://forums.plex.tv/categories/podcasts
BANDWIDTH
PLEXTVMX2018PLEXTVMX2018 Posts: 2Members
GOOD DAY, FROM THE LAST UPDATE, I REMOVE AN ERROR THAT SAYS THAT IT CAN NOT BE REPRODUCED BELOW THE MINIMUM OF BAND WIDTH, 103 KB I HAVE 100 MB AND DID NOT PASS THIS, WORKING WITHOUT PROBLEMS UP TO THE LAST UPDATE? SOMEBODY HAPPENED TO YOU?
"THERE IS NO SUFFICIENT BANDWIDTH TO REPRODUCE THIS ELEMENT, IT CAN NOT BE CONVERTED BELOW THE MINIMUM BANDWIDTH OF 103 KBPS. DIRECT PLAY OR CONVERSION NOT AVAILABLE"
