Adding track rating and playlist info from tag when importing music
TravillionTravillion Posts: 35Validating, Plex Pass Plex Pass
I am trying to automate aspects of my music library in Plex and am wondering if this could be handled by a custom agent.
When I purchase and rip new music outside of Plex I add the track rating as a metadata tag. I could also do this for desired playlist(s). I am wondering if I could set up a Plex agent that would read the rating from the tag and apply that same rating in Plex. Also, it would be great if it would read the playlist tag and then automatically add that track to the identified playlist(s) in Plex. I am new to plugin development and am not sure how to read the tags since Plex by default does not read ID tags, and how to add the tracks to specific playlists as I did not see that in the API documentation.
Any pointers would be appreciated. Thanks!
Answers
  • stevegagnestevegagne Posts: 2Members, Plex Pass Plex Pass
    I have the same issue. I've been using J. River for years but always have problems with networking. I use Plex for movies and the networking feature is great. I have been exploring replacing J. River with Plex for music but am struggling with smart playlist creation, which is an absolute necessity for me. I understand that custom filters may allow me to create smart-like playlists but I can't experiment with it because my track ratings don't appear in Plex. The rating is in the tag but Plex doesn't display it and attempts to filter on track rating comes up empty.
    Is there a way to cause Plex to bring metadata in from the embedded tag. I am most interested in bringing in track rating but I would also be interested in bringing in any other tag metadata that is missing in Plex.
  • TravillionTravillion Posts: 35Validating, Plex Pass Plex Pass
    There is no way to import music tag information as far as I know. Plex may be fine for building a music library, but it couldn't be much worse for assuming control of a large, existing library.
    There is a way to build a library based on an iTunes library (which includes ratings), but this requires you to come from iTunes, and it was still pretty bad when I tried it. I got lots of partial playlists and half of my ratings didn't migrate over.
    I found a python script that reliably imports playlist files (e.g., .m3u) and then builds a matching playlist in Plex. My initial thought was to create playlist files based on rating, import them into Plex, and then assign ratings in Plex en masse. Unfortunately, you can only select one track at a time in a Plex playlist, which for me still means individually assigning ratings for thousands of songs. Not going to happen!
    I believe it is probably possible to modify the playlist python script to write track ratings instead of/in addition to playlist, but I haven't figured out how yet.
