Plex behaving strangely when adding libraries.
GazrichGazrich Posts: 2Members
Hi first time post sorry if I mess or miss anything.
I am running Plex 1.10.1.4602 on a Synology ds114se using Windows 10 experiencing the following problems when adding folders using the web interface. Strange things happen The language drop down is unavailable (or sometimes says none or sometimes) as is the Next button. another time the next button may be lit but nothing happens when I press it other times Is presses ok but I get an Error "your changes could not be saved" when I add Library sometimes it evens allows me to add a folder but not any more.
I have tried the usual reinstall and 2 versions of the software (installing manually with the .spk downloaded from Plex's web site and directly downloading from synology package centre. I have deleted the plug-in folder and re ran but nothing.
Can anyone offer any Help?
I have the server running perfect on 2 laptops just not my NAS.
Logs Attached.
Many Thanks
Best Answer
Answers
  • GazrichGazrich Posts: 2Members
    Hi Andy Thanks for your replay.
    I have had Plex running really well on this server in the past despite its low spec.Its never been able to handed really high def stuff but is good for music.I am at the moment just using it for storage as you say,, with plex sever on my laptop but would like it running as it was before. I will have a proper look at the repair later.
    Tar
