HiFiBerry DAC+Light not recognised
PLEX6FCPLEX6FC Posts: 84Members ✭✭
edited December 2017 in Rasplex
Hi all,
_
Raspberry Pi 3
RasPlex (official) Version: 1.8.0.148-573b6d73
HifiBerry DAC+Light HW 1.3_
I edited boot/config.txt as per: https://support.hifiberry.com/hc/en-us/articles/205377651-Configuring-Linux-4-x-or-higher
By commenting out LIRC and un-commenting hifiberry-dacplus, so it now reads:
_################################################################################
# >>>>>>>> RasPlex default settings override <<<<<<<<<
# Required overlay for LIRC to function
# dtoverlay=lirc-rpi
# Required for hyperion / lightberry
  dtparam=spi=on
# Uncomment to enable the sdhost driver
# dtoverlay=sdhost
# Uncomment to enable HiFiBerry overlay
# NOTE: You must disable the lirc-rpi overlay (or change lirc GPIO pin) for HiFiBerry to work correctly
# dtoverlay=hifiberry-amp
 dtoverlay=hifiberry-dacplus
# dtoverlay=hifiberry-digi_
Over SSH, when I run aplay -l I get this:
RasPlex:~ # aplay -l
aplay: device_list:268: no soundcards found...
Any ideas?
(Just to confirm; yes, the card is plugged in...)
Cheers, Scott
Best Answer
Answers
