Cannot control chromecast audio, instead get message that surround sound is enabled, use tv remote
HardFlameHardFlame Posts: 1Members
So I am using a plex media server (updated to newest version half an hour ago), streaming media over ethernet to my chromecast ultra. I cannot change volume from my android device or my google home assistant, when I try it tells me that surround sound is on and to use the tv remote.
Is this normal for surround sound not to be controllable from chromecast? I've never had this issue streaming any other content outside of plex media server. Is there a way for me to disable surround sound (I don't have that many speakers anyways) so that I can get volume controls back? Lack of native volume control isn't really an acceptable answer from my point of view.
Everything looks and sounds great, but I really want to be able to turn the volume up or down without having to search for a tv remote.
Answers
  • kristianvollmer@gmail.comkristianvollmer@gmail.com Posts: 1Members, Plex Pass Plex Pass
    I'm having this problem too, its only started happening recently as well.
  • abciabci Posts: 1Members
    Me as well. Can't find setting to disable. No obvious way to gain control.
  • giuseppebaldigiuseppebaldi Posts: 9Members, Plex Pass Plex Pass
    Happened to me too today. Looked into it for quite awhile but couldn't find any answers or settings that might fix it. I did notice though, that on my end, it only does it with movies in 5.1. Played another movie right after and didn't have any problems controlling the volume via the phone/Chromecast.
  • tveithtveith Posts: 47Members, Plex Pass Plex Pass
    Started happening to me today also. Wtf.
  • emilianoheynsemilianoheyns Posts: 2Members
    I'm seeing the same thing in Netflix though. Must be a chromecast problem.
  • lespaul00lespaul00 Posts: 11Members ✭✭
    Any update on this? I have the same issue
  • mv03790@gmail.commv03790@gmail.com Posts: 1Members, Plex Pass Plex Pass
    I'm having this issue too
  • jkmcwhorter.et.all@gmail.comjkmcwhorter.et.all@gmail.com Posts: 2Members, Plex Pass Plex Pass
    I've been having the issue as well, but after converting the audio file in handbrake it works just fine. Change the audio file to one that works like mp3 and make sure the mixdown is stereo (I'm still a noob with this software and AV files but I know that works). If you don't want to lose your 5.1 mixdown you can do all this reformatting and duplicate the audio file (as many as you like) with differing mixdowns. I keep most of my 5.1 because I plan on getting a better sound system but for now I just have my tv. Be warned though, this will increase the file size.
    Software: Handbrake
    Supported Chromecast codecs: https://developers.google.com/cast/docs/media
  • barrystaesbarrystaes Posts: 29Members, Plex Pass Plex Pass
    edited January 21
    Same problem since a few weeks.
    Quite frustrating together with transcoding stutter unless i revert 'Auto/20Mbps' to 'Original Quality' which might not be related but started at the same time.
